Old 06-29-2008, 04:21 AM   #1 (permalink)
Old_Gregg92's Avatar
Car: 1992 Civic D16Z6T
Old_Gregg92 is on a distinguished road
Question D16Z6 machine work = down time. So a Question! HElP!
I currently have a D16Z6 and its old and tired. Time for a rebuild. So I have a few questions for you guys. As this is my only vehicle I need to have as little down time as possible. Here's what I'm wanting to do. Have it bored to 75.5mm, EVERYTHING balanced, and parts are as follows: TT rods, vitara pistons, ACL main and rod bearings.
My question is this. Should I find a spare D16Z6 block and crankshaft and have them sent to the machine shop along with my parts to have everything balanced and ready to be assembled? Or would I need to buy more than just the block and crankshaft?
--I know I'm probably forgetting something, but I'm sure you guys will point my in the right direction. Thanks in advance.
Another question would be what parts are missing from my list (if any)? All tips and suggestions are appreciated as I want to do this right the first time.
I'm Old Gregg!
Old_Gregg92 is offline
Old 06-30-2008, 02:43 PM   #2 (permalink)
kommon_sense's Avatar
Car: 98 Civic Ex Coupe
If you can't afford downtime then just buy a spare block/crank and then sell your current block/crank when you are done with the swap.
Instead of TT rods, I'd look into the lightweight rods from Blueprint Manufacturing - Quality Performance Parts . They should be about the same cost.
Add a set of ARP rod bolts as they are the weakpoint in the bottom end.
Its been a while since I've researched d-series bearings, so use whatever works for you there.
You mentioned vitara pistons, so I assume you plan to boost.
You will also need new gaskets. Might as well go ahead and tap the oil pan for your return line while you are at it. Add in some baffles in the pan as well. Get a new oil pump. Consider getting it ported by The Old One - Energy Dynamics .
Also get ARP main bolts as well. You want that bottom end buttoned up as well as you can get for a reliable build.
Also a good time to drop in a better radiator. If you don't have A/C, then go ahead and get a full width radiator (good if you plan to boost), or just get something like a delsol dual core rad, or an aftermarket aluminum rad like the mishimoto, koyo, fluidyne, etc.
kommon_sense is offline
Old 07-01-2008, 04:42 AM   #3 (permalink)
Thanks for the information.
I'm Old Gregg!
