Old 07-18-2007, 01:34 AM   #1 (permalink)
94coppercivic is an unknown quantity at this point
help with gsr rear brake conversion to a 94 civic
i have all tha parts that i need to do the conversion except the proportioning valve. I have never done it before is it easy and wat does it consist of???
94coppercivic is offline
Old 07-18-2007, 08:22 AM   #2 (permalink)
SH Virus
Jo060's Avatar
Mods: fuggin' your mom.
Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?
It is fairly easy. You went out and bought all the parts buy you dont have a clue of what it consists of?
Maybe do some research before you even touch a THING. Use the button above, it says "SEARCH"
MEMORIZE THIS NOOBS
Fast+Cheap=Not Reliable
Cheap+Reliable=Not Fast
Fast+Reliable=Not Cheap
4 Doors are the best!!
Jo060 is offline
Old 07-19-2007, 07:15 AM   #3 (permalink)
klungemonger's Avatar
Car: 98 Civic DX hatch
The hardest part is doing the prop valve and bleeding it properly. Everything else is just bolt-in stuff, pretty basic. You should be able to tell just by looking at the parts you have how they come off the car and everything new goes back in exactly the same. You will need an alignment afterwards to get the camber and toe set right. I think you use a 92-95 Si prop valve, iirc they had rear disc so that should work.
klungemonger is offline
Old 07-20-2007, 01:54 AM   #4 (permalink)
thats wat i thought and was told.i was told to get a gsr prop valve???i have tha brakes 4 the front 2> mad props on that car!!!!! wat whp are u shooting 4?
Old 07-20-2007, 05:54 AM   #5 (permalink)
OK you have all 4 discs...yeah then a GSR prop valve will do the trick. Usually the Integra front brakes/calipers are larger than the Civic so proportioning is a little different even than the stock 4-disc Civics.
Are you talking about my car? Sorry I have sigs turned off so I don't see anyone's pics or setups (I'm at work, need to keep low profile!) I also have the full 4-disc GSR conversion on my hatch, hoping to put an H22 swap in soon, although I might sell it right away to buy a WRX from my friend who's moving out of the country.
Old 07-20-2007, 07:37 AM   #6 (permalink)
noway is an unknown quantity at this point
when I did my rear brake conversion I didn't change the proportioning valve and everything worked GREAT.
noway is offline
Old 07-20-2007, 09:05 AM   #7 (permalink)
It all depends...sometimes the prop valve for small front disc w/rear drums is the same as the large front disc w/rear disc setup, as is the case with EK hatches & the EK Si...
Old 07-20-2007, 10:09 PM   #8 (permalink)
thanx 4 tha help!!!im goin to start on it now!!!!!i was @bumper and they said i cud get an aftermarket 1 n it wud be adjustable>wud that be tha way ta go???
Old 07-21-2007, 10:05 PM   #9 (permalink)
I wouldn't do that...do you know how to set the proportioning for your brakes? I bet Honda does...
