Ah I see. Well I think a turbo on an HX would actually perform quite well if dialed in right, but it will still be a bit tricky doing it. It's not that hard to tune regular VTEC, you just know where the crossover is and tune the fuel for before it kicks in, then tune the section of RPM band in VTEC. But the VTEC-E system is different, it is not solely dependant on RPM to determine the crossover point because there is no change of cam profile. It does only change above a certain RPM but it also senses engine load and throttle position to "intelligently" determine if you really require the VTEC or not. VTEC-E is not a hi-cam/lo-cam switch, it's a 12-valve/16-valve switch.
So what I'm saying is tuning for boosted VTEC-E I guess you could get close but you might end up, depending on how you are driving at any given time, with a rich or lean condition because it kicked in later then expected, or sooner.
If you do try it though, Boomslang makes no-splice add-in harnesses for any car to install the Neo. They are expensive though, like $140...
