Originally Posted by blackouthx
wtf the Y8 is OBD2 so your all good in that area, I think he just wants to know how they differ in size/specs
He asked what he would have to do to run a y8 intake manifold on his y5.
The only way the y8 would work on a y5 is if you convert to obd 1 with a different ecu that won't be looking for the egr valve. If you stay obd 2 and use a y8 intake manifold on the y5 you will throw a code. I don't think it would work properly with a y8 ecu because the vtec-e mechanism is different then the regular vtec one. I'm pretty sure the y8 is alittle better flowing.
