Mods: cold air inake,dc 4-2-1 sports,cat back full exhuast
Install 95 Civic Intake manifold?
Hello, Guys I wannna install a intake manifold on my car. How hard is it. I have all the tools needed. Do you have any DIY?Also, would i have to mess with any fuel coming out of the fuel rail or anything.
nah you wouldent have to worry about alot of fuel spilling out cause your fuel pump pushes the fuel through the lines, anywho its quite easy and bold, just make sure you get a new gasket with that bad mamma jamma. but its pretty simple just put all parts back from where you got them from, injectors ect. let us know how you make out brudda good luck!
check out the y7 to y8 intake naifold swap tutorial in the stickies, its has a basic step by step on how to. even if it was for the 95 civic, the process is in general the same. just exclude the stuff about the iacv, and extending wires.
i also have a bare y8 intake manifold for sale. 35+shipping
'90 crx Si
punk....., but do they get the manifold support as well????
