Old 01-18-2007, 07:59 AM   #1 (permalink)
Car: 1999 Honda Civic Dx
Mods: Vibrant catback 2.25", Vibrant short throw, custom cold air intake, nology hotwires, ngk iridium plugs, front upper and rear lower strut bar
ek_sleeper is on a distinguished road
Mini Me vs. ZC
hey all,
let me know what you think about this.. this guy at the local shop i go to is supposed to do a mini me for me and hes trying to persuade me to do a ZC swap instead. something seems weird to me about this... Is a mini me unreliable or something or is it to much hassle? From what i've read on some forums a mini me doesnt look to complicated and its pretty straight forward if you have all the right parts..i think that theyd proabably be in the same power class in terms of hp and tq right? What do you think about that?
ek_sleeper is offline
Old 01-19-2007, 05:26 PM   #2 (permalink)
Car: 2000 Civic EX
Mods: I/H/E JDM d15b vtec LOADS of suspension
speedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep troposphere
what mini-me combo are you doing???
depending on which head/block combo you go with compression is bumped up and wil net more power, also use a d16y8 headgasket for sligtly higher CR, will net you about 10:1 or 10.75:1 depending on combo as stated above.
for best results use 91 or 93 gas and get it dyno tuned!!
and yeas a mini-me is EASY as all hell its just a head swap, may require vtec wire depending on year and also different headbolts depending on combo.
GIVE more info.
a zc is a bit underrated tho its 120-130hp easy.
MY VOUCHERS:
-Paypal:danijel_danicic@hotmail.com
-Ebay:dado03235
Originally Posted by riceboy89
nice setup man
(speedjunky01)your mom is so jdm!
CIVIC PRESSURE PLATE *CHEAP*
speedjunky01 is offline
Old 01-20-2007, 04:22 PM   #3 (permalink)
currently i have a d16y7 in my hatch and i do plan on throwing the y8 head on it.. i actually have a really good DIY that i searched and found. What kind of power gain would i be getting over the stock 106 of the hatch.. would it possibly get the same HP rating as the y8 motor? I have a few mods on the car already.. i have a catback 2.25" exhaust, custom cold air intake and a short throw. I am getting a 4-1 header and ceramic core cat on tuesday. Any opinons are only help to me.. thanks for replying!!
Old 01-20-2007, 04:34 PM   #4 (permalink)
Car: 2000 Civic EX
I would say around 140hp without tuning.
if you dyno tune it really nicley you should see 125whp if done really well.
MY VOUCHERS:
-Ebay:dado03235
nice setup man
Old 01-22-2007, 05:55 AM   #5 (permalink)
125 whp sounds pretty sweet...should i think about changing anything else besides what's recommended (gaskets, studs, timing belt etc..)? Should i look into a cam gear or a crank pulley?? i figure its probably easier to throw that on while the motor is half apart right? then that way i get tune it for a little bit more.. in your opinon though.. 2 ek civics.. one with a ZC and one with a mini me.. same skilled driver.. doing 60mph.. who would pull away full throttle??
p.s. thanks for your help!!
Old 01-22-2007, 09:08 AM   #6 (permalink)
Car: 2000 Civic EX
it would be a pretty even pull but the mini-me would edge it out and win in the end.
MY VOUCHERS:
-Ebay:dado03235
nice setup man
Old 01-22-2007, 09:12 AM   #7 (permalink)
Chinese Acrobat You need a lifeChinese Acrobat You need a lifeChinese Acrobat You need a lifeChinese Acrobat You need a lifeChinese Acrobat You need a lifeChinese Acrobat You need a lifeChinese Acrobat You need a lifeChinese Acrobat You need a lifeChinese Acrobat You need a lifeChinese Acrobat You need a lifeChinese Acrobat You need a life
I got a 98 DX
I got a Y8 head and Z6 IM do I need anything (parts) else?
DEL SOLS
Buy my ish
Chinese Acrobat is offline
Old 01-22-2007, 09:19 AM   #8 (permalink)
Car: 2000 Civic EX
an ecu to tune it with. gaskets and other mist shit. Im pretty sure you can use the y7 distributor.
should be all set.
MY VOUCHERS:
-Ebay:dado03235
nice setup man
Old 01-22-2007, 01:00 PM   #9 (permalink)
I got a P2P ecu
DEL SOLS
Buy my ish
Old 01-22-2007, 01:08 PM   #10 (permalink)
Car: 2000 Civic EX
Originally Posted by Chinese Acrobat
I got a P2P ecu
thats close to what you would want but a mini-me bumps compression a little bit so idealy you would want a p28+dyno time.
MY VOUCHERS:
-Ebay:dado03235
nice setup man
Old 01-23-2007, 05:15 PM   #11 (permalink)
So you'd want me to convert to obd1?
DEL SOLS
Buy my ish
Old 01-23-2007, 05:31 PM   #12 (permalink)
Car: 2000 Civic EX
that would be ideal but its not 100% necesary, car willrun pretty decent with the p2p for sure.
MY VOUCHERS:
-Ebay:dado03235
nice setup man
Old 02-03-2007, 03:48 AM   #13 (permalink)
Car: 1988 civic (J)
Mods: B20b B16 head CTR cams type R intake ITR header MSD ignition password whale penis intake spoon PR3 and VTEC controller Gea
xxxdoc is infamous around these partsxxxdoc is infamous around these parts
ZC all the way I have a jdm zc single in a gutted 90 hatch Ive smoke a 99 gsr No Bs por guy was running rich I had to get out of the throttle the final drive helps out Balls to the walls!
xxxdoc is offline
Old 02-07-2007, 06:49 AM   #14 (permalink)
how much do zc motors cost? and will my dx tranny work with the motor or do i have to get like an ex tranny?? a 90 hatch weighs what like low to mid 2000 lbs? i think my 99 weighs in some where around 2700lbs?? will it still do some damage?? for what my buddy is telling me i can pretty much use all the after market parts that i already have on my car like the header, full catback, and custom cold air... he says that they should bolt right up to the zc.. i hope hes right.. also.. since you have the zc.. what kinda cams and pistons are available for zc's?? im sure its a lot better than whats available for my y7.. you guys are helping a lot thanks so far!!!!
Old 02-08-2007, 01:23 AM   #15 (permalink)
Punx122's Avatar
Car: 98 Civic Ex sedan
Mods: VTAK
Punx122 has a spectacular aura aboutPunx122 has a spectacular aura aboutPunx122 has a spectacular aura about
I'm confused, is the ZC a vtec engine? I was poking around on a JDM website and it said 96+ ZC...I thought it was an older model.
Punx122 is offline
