Old 07-28-2007, 11:56 AM   #1 (permalink)
matchboxboy is an unknown quantity at this point
mis-firing
my 95 d15 is mis-firing i changed the rotor, cap, spark plugs, and plug wires and its still doing it. when i pulled out one of the spark plugs its was dripping in oil. i think that would be my problem. how do i fix that?
matchboxboy is offline
Old 07-29-2007, 10:03 AM   #2 (permalink)
weewoo's Avatar
Car: Nine Three hatch
Mods: Currently Stripped completely....Fuckin Crooks.
weewoo Needs a boyfriend/girlfriendweewoo Needs a boyfriend/girlfriendweewoo Needs a boyfriend/girlfriendweewoo Needs a boyfriend/girlfriendweewoo Needs a boyfriend/girlfriendweewoo Needs a boyfriend/girlfriendweewoo Needs a boyfriend/girlfriendweewoo Needs a boyfriend/girlfriendweewoo Needs a boyfriend/girlfriendweewoo Needs a boyfriend/girlfriendweewoo Needs a boyfriend/girlfriend
first thing to do is run a compression test to see if any cylinders have leaks.
if you do you might have a valve leak or maybe a head gasket .
BAMF Camaro
weewoo is offline
Old 07-29-2007, 01:08 PM   #3 (permalink)
HondatechAV6's Avatar
Car: 2000 Accord Lx V6
when you say it was dripping in oil do you mean b4 or after you pulled the plug out?
if it's b4, the spark plug tube seals a leaking, and that can cause your misfire.
if it's after you pull the plug out, either the valve seals are leaking or the oil control rings are bad.
I'm just a nice guy.
HondatechAV6 is offline
Old 07-29-2007, 06:34 PM   #4 (permalink)
yea it was leaking when ipulled the spark plug out but its only on one plug
Old 07-29-2007, 08:37 PM   #5 (permalink)
are you sure it is oil?
if it's black from fuel it will evaporate.
if it's oil it will stay wet for a good while.
Old 07-30-2007, 06:37 PM   #6 (permalink)
im positive its oil. could that be why my car burns oil? cuz i do a oil change and like within a month i need another quart. i know the car smokes bad when im in high rpm but is that cuz of the oil on the spark plug?
Old 07-30-2007, 08:29 PM   #7 (permalink)
weewoo's Avatar
yes its because of oil leaking past the piston into the combustion chamber.
sounds like you need new rings.
run a compression test on all cylinders record the readings. do the compression test 3 times on each cylinder and record all the readings.
post up your readings and maybe we can further asist you.
BAMF Camaro
weewoo is offline
Old 07-31-2007, 11:35 AM   #8 (permalink)
Car: 97 civic with a 99 ex engine
Mods: well aqbout to have a GSR complete swap ecu tranny all that or a K20A2 complete swap
97civicr is an unknown quantity at this point
my 99 D16 had that same problem except it wasnt dripping i just had a leak into the firts spark plug i just boutgh a new valve cover gasket and new spark plug rings and now its just fine and runs greta so u should try that or since u already did the rings try the valve cover gasket it would probably be like 10 bucks if that cuz the whole set cost me 25
97civicr is offline
Old 07-31-2007, 06:18 PM   #9 (permalink)
ok i so i fixed it today. it was the damn spark plug wires. i dont know what was wrong with them but i bought new ones and put them on and drove all day today so its all good but thanx everyone for ur help
Old 07-31-2007, 10:37 PM   #10 (permalink)
weewoo's Avatar
never heard of wires making your car smoke though
BAMF Camaro
weewoo is offline
Old 08-01-2007, 10:59 PM   #11 (permalink)
nooo the wires were my mis firing the smoking is my piston rings but im going b16 next week (as soon as my axles and mounts come in) so i dont care
Old 08-02-2007, 04:59 AM   #12 (permalink)
that kills me...lol
"HELP HELP!!"
3,000,000 eager ppl trying to save the day posts...
"yeah, i'm ditching the car anyway..."
Old 08-02-2007, 01:24 PM   #13 (permalink)
matchboxboy69 is an unknown quantity at this point
lmao sorry but thanx for the help
matchboxboy69 is offline
Old 08-02-2007, 07:19 PM   #14 (permalink)
weewoo's Avatar
Originally Posted by HondatechAV6
that kills me...lol
"HELP HELP!!"
BAMF Camaro
weewoo is offline
Old 08-02-2007, 07:24 PM   #15 (permalink)
