Old 08-21-2008, 12:01 PM   #1 (permalink)
Dark Wind
The_Producer's Avatar
The_Producer In the rep troposphereThe_Producer In the rep troposphereThe_Producer In the rep troposphereThe_Producer In the rep troposphereThe_Producer In the rep troposphereThe_Producer In the rep troposphereThe_Producer In the rep troposphereThe_Producer In the rep troposphereThe_Producer In the rep troposphereThe_Producer In the rep troposphereThe_Producer In the rep troposphere
Mystery OIL leak...
Okay... I have a strange problem... again!
I have a 00 civic EX auto (4dr) (101K miles)
The problem is that when I drive the car to work, the gf's, or wherever, I don't seem to see oil leaking from under the car, and I've checked. I started checking as soon as I noticed droplets of oil under my vehicle... ONLY in my garage.
I went out yesterday and the spot has gotten HUGE! I looked under the car, I can not seem to find where it is coming from. The spot is relatively larger than normal after getting my oil changed. And so far I've had 2 oil changes since I've owned the car (bought it used) and each time it has smoked as if oil was spilled onto the exhaust manifold. There is no smoke IN the actual exhaust, just under the hood. So, the smoke stops after the first day and I have checked the spot where the oil filter is at and there seems to be no leaks. There are no leaks at the oil pan plug either.
The head gasket has no leaks, but there is a bit of residue near where the transmission mounts to the engine, however, there is no collecting of oil that would create drops or puddles on the ground there, plus the spot seems to be centered under the engine. I can't seem to find any residue on the vehicle. Could it be the oil pan gasket? How long do they normally last? I don't think it's ever been replaced.
The_Producer is offline
Old 08-21-2008, 04:10 PM   #2 (permalink)
Car: 94 civic dx
Mods: d16y8, ported+polished head, K04 turbo, race werks manifold, 2 1/2" dnx exhaust, borla muffler, fidanza superlight flywheel, zoom stage2 clutch, tokico illumina struts, skunk2 adjustables, energy suspension bushings, kosei k1 wheels, falken rubbers, jdm typeR steering wheel, gutted rear, HID kit, pioneer headunit
skibee1000 Hello down there miniscule peonsskibee1000 Hello down there miniscule peonsskibee1000 Hello down there miniscule peonsskibee1000 Hello down there miniscule peonsskibee1000 Hello down there miniscule peonsskibee1000 Hello down there miniscule peonsskibee1000 Hello down there miniscule peonsskibee1000 Hello down there miniscule peonsskibee1000 Hello down there miniscule peonsskibee1000 Hello down there miniscule peonsskibee1000 Hello down there miniscule peons
check your valve cover gasket and check your oil drain plug... it sounds like its either dripping onto your manifold or onto your exhaust under the drain plug.
skibee1000 is offline
Old 08-21-2008, 10:10 PM   #3 (permalink)
Dark Wind
I've already mentioned that it is NOT either of those....
I am thinking now that it might be the crankshaft oil seal??
Old 09-12-2008, 08:29 PM   #4 (permalink)
Accelerazn's Avatar
Car: 02 s2k SebringS
Accelerazn Needs a boyfriend/girlfriendAccelerazn Needs a boyfriend/girlfriendAccelerazn Needs a boyfriend/girlfriendAccelerazn Needs a boyfriend/girlfriendAccelerazn Needs a boyfriend/girlfriendAccelerazn Needs a boyfriend/girlfriendAccelerazn Needs a boyfriend/girlfriendAccelerazn Needs a boyfriend/girlfriendAccelerazn Needs a boyfriend/girlfriendAccelerazn Needs a boyfriend/girlfriendAccelerazn Needs a boyfriend/girlfriend
what you do is get one of those carb cleaners, and spray down your whole engine and tranny area clean. Once the engine is clean see where the oil is leaking from.
Based on your description it doesnt necessarily mean it's coming from the oil pan.. it could be dripping down from the top somewhere too.
It could be your valve gasket or your distributor seal. Oil tends to leak from there quite often
1993 Civic Si Hatch (so far) - neuspeed race/bilstein hd, 15" OZ ultraleggeras, DC2 ITR steering wheel (non-srs), RSX 5spd SK, Spoon front/rear strut bar.
2002 S2000 - Zeal Function XS coilovers, T1R 70R w/ GTm CF Single Exhaust Cap, Enkei RPF1s, ASM FRP Rear Trunk Spoiler, Personal Neo Grinta Steering Wheel w/ Works Bell rapfixII quickrelease, Spoon X-brace, Spoon Strutbar and lower tiebar (BLING!), ARC Ti Shift Knob, Shine side diffusers, Rick's clearcorners, Clear sidemarkers. Upcoming: J's SPL header, pjdm ram intake.
Accelerazn is offline
Old 09-14-2008, 12:29 PM   #5 (permalink)
SH Virus
Jo060's Avatar
Mods: fuggin' your mom.
Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?
You said head gasket, not valve cover gasket
It's worth getting under there to check the oil pan gasket. Very simple check and fix.
Like you said, could be the camshaft seal, mine went bad on the Integra.
Did you change the oil yourself?
This is prob. not it..but worth a check. Take a look at the...er...I can't think of the name right now. The tube that is coming off the intake, see if there is oil in that.
MEMORIZE THIS NOOBS
Fast+Cheap=Not Reliable
Cheap+Reliable=Not Fast
Fast+Reliable=Not Cheap
4 Doors are the best!!
Jo060 is offline
Old 09-16-2008, 09:27 AM   #6 (permalink)
AznMuscle's Avatar
Car: 1999 Trans Am
Mods: Lid, Cutout, 4.10s
AznMuscle has a Rep problemAznMuscle has a Rep problemAznMuscle has a Rep problemAznMuscle has a Rep problemAznMuscle has a Rep problemAznMuscle has a Rep problemAznMuscle has a Rep problemAznMuscle has a Rep problemAznMuscle has a Rep problemAznMuscle has a Rep problemAznMuscle has a Rep problem
Do these cars have PCVs that tend to leak a lot? I know on ls1s, you will burn excessive oil through the PCV, and even get it into the tb and into the intake mani. That could be a problem, if d motors are equiped with it.
1999 Trans Am m6-FTP lid||SLP 85mm MAF||Cutout||4.10s
c5 zo6 wheels: 18x9.5 in front and 18x10.5 back, nitto 555, 255 front/285 back. And still had to do BFH
Originally Posted by cascadesys View Post
Who knows, but who cares. You do an LS1 swap for yourself, not for resale. It would be like buying your girlfriend breast implants then dumping her...why do it if you aren't going to get to enjoy it?
AznMuscle is offline
