Old 06-30-2006, 10:08 AM   #1 (permalink)
j93hondahatch is an unknown quantity at this point
Exclamation need help
need help how do i take manual transmission off d15
j93hondahatch is offline
Old 06-30-2006, 10:11 AM   #2 (permalink)
Cruise Control you're still here?Cruise Control you're still here?Cruise Control you're still here?Cruise Control you're still here?Cruise Control you're still here?Cruise Control you're still here?Cruise Control you're still here?Cruise Control you're still here?Cruise Control you're still here?Cruise Control you're still here?Cruise Control you're still here?
unbolt it from the motor and rock it to get it off the splines
don't forget to take out the starter
Cruise Control is offline
Old 06-30-2006, 10:12 AM   #3 (permalink)
do i have to take any bolts from flywheel off
Old 06-30-2006, 10:17 AM   #4 (permalink)
nope, if it was auto you would need to take off the torgue converter
also there is a plate that covers the flywheel you have to take off,
Old 06-30-2006, 10:22 AM   #5 (permalink)
is it 4 12 point 10 mm bolts that connect to the flywheel
Old 06-30-2006, 10:25 AM   #6 (permalink)
flywheel is bolted to the motor not the tranny
you can leave the flywheel on till you get the tranny out
when its out you have to take the clutch off first, they are 12 point 10 mm
then the flywheel, which is 12 point 12 mm, or 14 mm. I don't remember off hand
Old 06-30-2006, 10:55 AM   #7 (permalink)
now the clutch is connected to the flywheel
Old 06-30-2006, 11:01 AM   #8 (permalink)
tranny is mounted to motor
after you get that off you can take off the clutch, which is bolted to the flywheel which is bolted to the motor
gotta take it apart in that order
Old 06-30-2006, 11:05 AM   #9 (permalink)
my problem is i cant get the tranny off i got all of the bolts off the motor but i cant get the tranny off
Old 06-30-2006, 11:10 AM   #10 (permalink)
the starter is out and the shield that is by the motor that bolts to the tranny is off
Old 06-30-2006, 11:11 AM   #11 (permalink)
all the bolts on the outside are out
Old 06-30-2006, 11:14 AM   #12 (permalink)
also the car was in gear when i took the linkage off
Old 06-30-2006, 11:14 AM   #13 (permalink)
is the tranny mount loose
is it in the car
if its loose, is it breaking apart at all, if its not, you have a bolt you are missing
try to slide a screwdriver between the 2 and break it loose
also try to rock it.
Old 06-30-2006, 11:15 AM   #14 (permalink)
doesn't matter, it won't affect it
Old 06-30-2006, 11:15 AM   #15 (permalink)
the motor and trans are out of the car
