Old 06-02-2006, 10:05 AM   #1 (permalink)
SH Virus
Jo060's Avatar
Mods: fuggin' your mom.
Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?Jo060 you're still here?
o2 Simulator.
EDIT: 1998 Civic DX
Hey! I bought an o2 simulator from summit the other day and I was sent the wrong one. I was sent item # 104053 instead of #104054 go figure. Anyway. Does this seem like it would fit? (this is a picture of the correct one) It doesn't look like it to me unless I am looking at the wrong spot to plug it into. The part that I thought the simulator goes into almost looks like a spark plug on the bottom of the cat (closest to the ground) Maybe I'm wrong. What do you guys think.
MEMORIZE THIS NOOBS
Fast+Cheap=Not Reliable
Cheap+Reliable=Not Fast
Fast+Reliable=Not Cheap
4 Doors are the best!!
Jo060 is offline
Old 06-02-2006, 11:18 AM   #2 (permalink)
Car: 93 prelude si vtec
Mods: jdm h22, header, high flow cat, cat back exhaust, cai, stage 1 exceddy clutch with 8 pound flywheel, gauges in a pod, system...much more to come
johnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhile
why wouldnt tyou just get a real o2 sensor? its better, and healthier for your engine. and i could peobably get you one for just as much as you8 paid for that contraption.
93 prelude, jdm h22a, lots of mods great car---FOR SALE
http://www.superhonda.com/forum/showthread.php?t=317981
2005 subaru sti---the beast
johnlude85 is offline
Old 06-02-2006, 11:43 AM   #3 (permalink)
SH Virus
Jo060's Avatar
The reason for the o2 simulator is because I am running with out a cat. And if I dont have one then I will have a CEL when I install this header.
MEMORIZE THIS NOOBS
Jo060 is offline
Old 06-02-2006, 12:54 PM   #4 (permalink)
Black Hole
ATISTANG's Avatar
Car: 79 Yugo
Just crawl under there and see if it plugs in
ATISTANG is online now
Old 06-02-2006, 01:02 PM   #5 (permalink)
snozepp147's Avatar
Car: 98 Honda Civic ex
snozepp147 In the rep tropospheresnozepp147 In the rep tropospheresnozepp147 In the rep tropospheresnozepp147 In the rep tropospheresnozepp147 In the rep tropospheresnozepp147 In the rep tropospheresnozepp147 In the rep tropospheresnozepp147 In the rep tropospheresnozepp147 In the rep tropospheresnozepp147 In the rep tropospheresnozepp147 In the rep troposphere
there should be a hole in the bottom of the chassis with a circular blue rubber thing that the o2 sensor went through to connect to the wiring harness- right over where the cat used to be, closer to where it met the header. that hole can be reached from the inside of your car-behind your center console, you might have to cut away some carpet. then just find where the o2 sensor plugs in, or did plug if it isnt there any more. there should be a matching plug for you to plug the o2 simulator in.
i had an o2 simulator for a while but in the end it wasn't worth and it just cause the CEL to come on. if you plan on running without a cat, i would consider an obd1 conversion, that way you won't need a secondary o2 sensor. but its up to you.
hope this helps
Weezer- Rivers' famous sonic blue strat '94-'97
snozepp147 is offline
Old 06-05-2006, 09:07 AM   #6 (permalink)
SH Virus
Jo060's Avatar
Does running without the cats o2 sensor for a little while affect anything?
MEMORIZE THIS NOOBS
Jo060 is offline
Old 06-05-2006, 09:45 AM   #7 (permalink)
Black Hole
ATISTANG's Avatar
Car: 79 Yugo
No, but other people will tell you otherwise, we had a long debate over this a few months back, let me find the thread and I'll let you read through it and you can decide for yourself
Old 06-05-2006, 09:56 AM   #8 (permalink)
Black Hole
ATISTANG's Avatar
Car: 79 Yugo
CEL code question.
Old 06-05-2006, 10:22 AM   #9 (permalink)
Car: 96 Civic dx
Mods: C.A.I , Blackheadlamps, Painted Interior, Custom Exhaust 2 1/4 in tubing
dxcivic96 is on a distinguished road
I'm running Header no cat , 3in tubing and a Glasspack . No CEL's so far . I just extend my o2 sensor by adding about few extra inches of wire . It sounds pretty good too. I'm testing out new maganaflow today.
dxcivic96 is offline
Old 06-05-2006, 11:02 AM   #10 (permalink)
SH Virus
Jo060's Avatar
I trust you, ATISTANG. We both have been around here for a while and all your posts are pretty damn good (funny too). So I'll just see what happens when I run with out a o2 on there.
Now, my other question.
Sence my CEL will be on after I do this, will I be able to tell if it throws another code later on for any other problem that comes up?
MEMORIZE THIS NOOBS
Jo060 is offline
Old 06-05-2006, 11:38 AM   #11 (permalink)
Black Hole
ATISTANG's Avatar
Car: 79 Yugo
not with out scanning for more codes, if you have a code scanner just scan it every once in a while or go to autozone like once a month and have them do it, then when they say you have a bad cat tell them you know and you don't care because your bad to the bone, then do a burnout leaving lol
Old 06-05-2006, 01:29 PM   #12 (permalink)
SH Virus
Jo060's Avatar
hehe! Right on brotha-man!
Thanks for the help +1
Edit: well, I lie. No rep for jew I must spred it around more before giving it to you again. It'll come though !
MEMORIZE THIS NOOBS
Jo060 is offline
Old 06-05-2006, 03:03 PM   #13 (permalink)
Black Hole
ATISTANG's Avatar
Car: 79 Yugo
its ok, I will forgive you
