Old 07-03-2006, 12:06 PM   #1 (permalink)
jthondaracer's Avatar
Mods: i wish i had mods
jthondaracer has a spectacular aura aboutjthondaracer has a spectacular aura aboutjthondaracer has a spectacular aura about
tech wrench project help
My dad and i decided we were going to do a civic project car and want to know were to start. We decided we liked the d16z6 head because my brother has an 95 ex with one and its pretty quick for being almost stock. (tops out about 130mph and with no traction runs a low 17). would it be better(cheaper and easier) to go with a d15b block and do a mini me swap building it from scrap out of the junkyard or to buy a complete motor????? We plan on making it a weekend racer and daily driver, a for fun car.
For the body i like 92-95 civic coupe and hatch back, i know the hatchback is lighter but is there any comfort in it for the daily driver part?????
Now i want it to go fast but my dad doesn't want it to be really loud so i opted for a cheap turbo to quiet it down and still be fast. Is it easy to get a stock mistsu t25, manifold, and down pipe converted to fit a civic,then buy the intercooler new from ebay or something, and will it be cheaper than buying a new turbo kit.(remember these are probaly going to be junk yard parts.) This project will be a cheap project. please help us were to start, thank you. :eek
jthondaracer is offline
Old 07-03-2006, 02:28 PM   #2 (permalink)
kommon_sense's Avatar
Car: 98 Civic Ex Coupe
I think that the coupe looks a little more sophisticated, but the hatch has all of the same creature comforts as the coupe. Just for a daily driver make sure that you plan for power steering and air conditioning. I'd recommend doing some of the simple things like :
- stock civic ex or gsr front swaybar
- stock gsr rear sway with gsr rear lower control arms
- stock integra front strut tower bar
- stock gsr front/rear brakes with booster, master cylinder, prop valve, etc.
- d16z6 motor with chipped p28 with uberdata
- rebuild the z6. arp head studs, new bearings, new rings. consider a block guard
- buy a transmission rebuild kit from www.gearspeedinc.com or www.sms-products.com
- plan for new shocks/springs and replacing worn bushings (which will be most of them)
don't forget that no matter how mild or street friendly you plan to make your build, you are still building a car that is *AT LEAST* 12 yrs old.
kommon_sense is offline
Old 07-03-2006, 02:51 PM   #3 (permalink)
Black Hole
ezeedee's Avatar
Car: 1994 Ford Explorer
ezeedee you're still here?ezeedee you're still here?ezeedee you're still here?ezeedee you're still here?ezeedee you're still here?ezeedee you're still here?ezeedee you're still here?ezeedee you're still here?ezeedee you're still here?ezeedee you're still here?ezeedee you're still here?
T25 turbo is pretty small, might restrict your top end a bit.
Good Read
since your gonna build your own kit, read that. Its pretty informative.
Good Luck!
Bigger, Badder, and Better
ezeedee is offline
Old 07-03-2006, 09:07 PM   #4 (permalink)
Good Read
Good Luck!
will this t3 be good seller says has some shaft play but spools up fine it has a day left on it and the bid right now is only $25 with no reserve. it is from an audi (found it on EBAY)
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
Old 07-03-2006, 09:31 PM   #5 (permalink)
Lightbulb
im confused there is a valve spring for every valve right???
Old 07-03-2006, 10:37 PM   #6 (permalink)
Black Hole
ezeedee's Avatar
yes, spring for every valve
i wouldnt buy the turbo with play in the shaft at all.
my .02
ezeedee is offline
Old 07-03-2006, 10:39 PM   #7 (permalink)
Premium Member
·Ądministrator·
JDM_Honda's Avatar
Car: 2003 VW GTi
Mods: CDA intake. 20psi. 3" full exhaust. Bailey's dv.
JDM_Honda You need a lifeJDM_Honda You need a lifeJDM_Honda You need a lifeJDM_Honda You need a lifeJDM_Honda You need a lifeJDM_Honda You need a lifeJDM_Honda You need a lifeJDM_Honda You need a lifeJDM_Honda You need a lifeJDM_Honda You need a lifeJDM_Honda You need a life
ya, you can find a better turbo than that, I suggest something like a 16G TD04
'97 Prelude Type SH *Sold*
'98 B18C swapped EJ6 *Sold*
'03 GTI 1.8T
My myspace!
JDM_Honda is offline
Old 07-04-2006, 01:03 PM   #8 (permalink)
type-r
would it be smart to buy that turbo than add one of those $75 rebuild kits off ebay, if so here is the link.
would it stop shaft play???????
Old 07-05-2006, 08:18 AM   #9 (permalink)
you can't properly rebuild a turbo yourself and you shouldn't buy a used turbo without plans to rebuild it. problem is you have to spin/balance the shaft at 10000+ rpms. Thats hard to do in your garage Check out :
www.majesticturbo.com for rebuilt turbos.
Old 07-11-2006, 08:38 PM   #10 (permalink)
tech wrench
when doing the "mini me" swap the best way to go would be a d15b block, d16z6 head, with a d16y8 manifold. right, if not what would be?????????????
Old 07-12-2006, 09:43 AM   #11 (permalink)
please use the search feature.
Old 07-12-2006, 11:30 AM   #12 (permalink)
whats that????????????????????????????????????
