Originally Posted by xxxdoc
I would set the intake valves almost at zero losen up the exhaust valves put some 91 in and play with the distrubtor reset the ecu and run it you can tune it yourself to some degree...
bood setup for bent valves or destroyed pistons
ok so what else did you touch except the header? did you extend the o2 sensor wiring? if so it can effect how the car runs becasue longer wiring can mean different readings.
as for the the valve adjustment .007 intake and .009 exhaust is best.
did you reset the ECU? you need to do this after any performance mod. disconect the negative battery terminal for 45 minutes. unless you messed with timing it will be same but check it its suposed to be about 12* BTDC
