Old 01-01-2007, 04:17 PM   #1 (permalink)
96sihatch is an unknown quantity at this point
some engine problems
i put a 96 ex motor in my 93 dx hatch and the motor seems to have nooooo power at all i put the motor back in time and it still have no power what so ever and its shaken like crazy like its chugging and miss firing i dont know what could be wrong im goin to try the distributer and also the wires and plugs does any one else know what this could be there are no vacume leaks and all sensors are good and the car hits vtec you could here it but its like runnin on like 3 cyclindersor less please let me know what u think
96sihatch is offline
Old 01-01-2007, 11:00 PM   #2 (permalink)
Lifeless Ninja
98civcEK's Avatar
Car: 98 Civic DX
are there any CEL's, which there should be if its misfiring. pull all of the codes and see if the computer sees something you don't
98civcEK is offline
Old 01-01-2007, 11:03 PM   #3 (permalink)
Car: 2000 Civic EX
Mods: I/H/E JDM d15b vtec LOADS of suspension
speedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep tropospherespeedjunky01 In the rep troposphere
um what ECU are you runing????
the obdII engine will HATE a stock obd1 engine lol.
MY VOUCHERS:
-Paypal:danijel_danicic@hotmail.com
-Ebay:dado03235
Originally Posted by riceboy89
nice setup man
(speedjunky01)your mom is so jdm!
CIVIC PRESSURE PLATE *CHEAP*
speedjunky01 is offline
Old 01-03-2007, 01:37 AM   #4 (permalink)
the only cel is o2 sensor but it was on in the last kids car i bought the motor off a good friend i mean we pulled it out of his cr on the right stall and dropped it right into mine in the left stall of the same garage i think that it may be the distributor is bad and also i am using the ex ecu
Old 01-03-2007, 06:44 AM   #5 (permalink)
Lifeless Ninja
98civcEK's Avatar
Car: 98 Civic DX
what year.....
p28 = 92-95
p2p = 96-00
98civcEK is offline
Old 01-03-2007, 11:53 AM   #6 (permalink)
p28
Old 01-03-2007, 01:04 PM   #7 (permalink)
Car: 2000 Civic EX
p28
thats your problem the 92-95 ex and 96-00 cvic maps are WAY different.
you can chip the p28 and run a p2p map from www.pgmfi.org
MY VOUCHERS:
-Ebay:dado03235
nice setup man
Old 01-03-2007, 08:18 PM   #8 (permalink)
wow i just looked at my originalk post and i didnt even realize the motor is a 95 and my car is a 93 my bad so now what im goin to try thr distributor and wires now but listen ok on the motor i got for the car the ex motor the map was on the throttlebody right well the old motor had the map on the fire wall now i have a map plug on the engine harness and also a map plug that comes from behind my battary to the map sensor on the firewall now how would i do this and also the map sensor on the fire wal calls for a vacume hook up no i switched to the throttle body so the vacume and the map sensor could be used from the fire wall should i be doin this or now and what should i be doin i feel the map has a huge affect with what is wrong so there for my final ? is this what throotle body what map sensor and what map sensor plug should i be using?????
Old 01-04-2007, 08:30 AM   #9 (permalink)
Lifeless Ninja
98civcEK's Avatar
Car: 98 Civic DX
if you have the ex engine harness you need to use that plug on the harness and the throttle body from the ex. the map will make that big of a difference if it is not hooked up right.
98civcEK is offline
Old 01-04-2007, 08:44 AM   #10 (permalink)
ok im goin to switch it back then today and also when i did have it like that it was throwing a cel map code why is this aaaaaaaaaaaaaaa i have obd1 wiring it sux soooooo bad
Old 01-04-2007, 08:48 AM   #11 (permalink)
and also im goin to switch the distributor to me it seems like it not firing right even if i out the plug wires in the wrong order it doesnt reallt change at all is the distributor from my old 1.5 the same it was non vtec?
Old 01-04-2007, 08:57 PM   #12 (permalink)
weewoo's Avatar
Car: Nine Three hatch
Mods: Currently Stripped completely....Fuckin Crooks.
weewoo Needs a boyfriend/girlfriendweewoo Needs a boyfriend/girlfriendweewoo Needs a boyfriend/girlfriendweewoo Needs a boyfriend/girlfriendweewoo Needs a boyfriend/girlfriendweewoo Needs a boyfriend/girlfriendweewoo Needs a boyfriend/girlfriendweewoo Needs a boyfriend/girlfriendweewoo Needs a boyfriend/girlfriendweewoo Needs a boyfriend/girlfriendweewoo Needs a boyfriend/girlfriend
im havin the same problem wit my civic.
its a 93 dx had stock 1.5 engine.
but i took a 1994 d16z6 outta a delsol automatic and never used the EX engine harness so my engine is running with the DX engine harness i TOO have 2 MAP sensor connections and dont know what to do
BAMF Camaro
weewoo is offline
Old 01-04-2007, 10:18 PM   #13 (permalink)
Lifeless Ninja
98civcEK's Avatar
Car: 98 Civic DX
because the ecu needs to have the readin from the t/b mounted one. it doesn't work right with the other.
your dizzy should work fine on it. its if you went from obd1 to obd2 it would be screwy. remember 1-3-4-2. if you need, take the cap off and look at what connection it is at when you have the motor at TDC. thats your #1 wire...and so on.
98civcEK is offline
Old 01-05-2007, 11:12 AM   #14 (permalink)
weewoo's Avatar
question.
i have 2 plugs for the MAP sensor. it would be hard to mistaken which connection goes where cuz the connector for the MAP sensor that is mounted on the firewall is alot shorter than the one that goes ontop of the TB
my question is . i have all my connectors plugged in but the MAP sensor on the fire wall really isnt serving a purpose. it just sits there and so what i did was just capped it off since i dont have an extra vacuum port available.
BAMF Camaro
weewoo is offline
Old 01-05-2007, 10:31 PM   #15 (permalink)
Lifeless Ninja
98civcEK's Avatar
Car: 98 Civic DX
Originally Posted by weewoo
question.
wheres the question....
98civcEK is offline
Linear Mode
