Old 05-21-2008, 03:49 AM   #1 (permalink)
AzJared is an unknown quantity at this point
sputter in first? Please Help
So i recently replaced my exhaust with a hks high power catback and no name headers a friend gave me. at first i only hooked up one 02 sensor cause i didn't have wire to extend the other and it would rarely sputter as i was steady on the gas in first. I extended the second sensor today and reset my check engine light, the light hasn't turned on since but it seems as though it sputters more often now, and only does it in first unless i accelerate fast. i thought it was just doing it being as i only had one sensor it but now i have no idea why anyone know what my problem is? Any help or things to check would be appreciated, thanks.
AzJared is offline
Old 05-21-2008, 01:19 PM   #2 (permalink)
kommon_sense's Avatar
Car: 98 Civic Ex Coupe
did you eliminate the cat as well?
did you reset your ecu after adding the 2nd sensor back in?
kommon_sense is offline
Old 05-21-2008, 02:19 PM   #3 (permalink)
i didnt eliminate the cat but replaced it with one from another model, and no i didnt reset the ecu i thought about trying that but i wanted to see what kinda of suggestions i got on here first, ill give that a try
AzJared is offline
Old 05-25-2008, 03:29 PM   #4 (permalink)
festivagt's Avatar
Car: 94 Eg coupe.
Plugged cat - crossed wires on O2 - other unrelated issue that might be caused by lack of maintenance to your engine or even just as simple as you might have knocked somthing loose while you were under the hood. What did the check light tell you? You should ALWAYS check the code BEFORE erasing it. You never know what might be causing the problem.
HENRY
festivagt is offline
Old 06-27-2008, 10:26 AM   #5 (permalink)
egcivic14701's Avatar
Car: 1993 civic
Mods: short ram intake, 4-2-1 header, cat back, strut bar.
egcivic14701 Needs to go outside once in awhileegcivic14701 Needs to go outside once in awhileegcivic14701 Needs to go outside once in awhileegcivic14701 Needs to go outside once in awhileegcivic14701 Needs to go outside once in awhileegcivic14701 Needs to go outside once in awhileegcivic14701 Needs to go outside once in awhileegcivic14701 Needs to go outside once in awhileegcivic14701 Needs to go outside once in awhileegcivic14701 Needs to go outside once in awhileegcivic14701 Needs to go outside once in awhile
I had the same thing happen to my eg. It was fouled plugs. it wont hurt to pull them and check them. Also inspect the wires. I had a broken plug wire that created a similar problem.
egcivic14701 is offline
Old 07-22-2008, 12:06 PM   #6 (permalink)
Car: 94 civic dx
Mods: d16y8, ported+polished head, K04 turbo, race werks manifold, 2 1/2" dnx exhaust, borla muffler, fidanza superlight flywheel, zoom stage2 clutch, tokico illumina struts, skunk2 adjustables, energy suspension bushings, kosei k1 wheels, falken rubbers, jdm typeR steering wheel, gutted rear, HID kit, pioneer headunit
skibee1000 Hello down there miniscule peonsskibee1000 Hello down there miniscule peonsskibee1000 Hello down there miniscule peonsskibee1000 Hello down there miniscule peonsskibee1000 Hello down there miniscule peonsskibee1000 Hello down there miniscule peonsskibee1000 Hello down there miniscule peonsskibee1000 Hello down there miniscule peonsskibee1000 Hello down there miniscule peonsskibee1000 Hello down there miniscule peonsskibee1000 Hello down there miniscule peons
do a regular tune up, and reset your ecu by simply unplugging the battery for a few minutes, and to be sure that its reset, your gonna want to pull out the "memory fuse" while the battery's out. and that fuse is located in the under-hood fuse panel.
skibee1000 is offline
Old 07-30-2008, 03:52 PM   #7 (permalink)
festivagt's Avatar
Car: 94 Eg coupe.
Pulling the 7.5 amp backup fuse does the same thing as pulling the cables off of the battery. The fuse is the power feed for the ECU when the Key is off. Double duty?
HENRY
Old 08-03-2008, 11:03 AM   #8 (permalink)
Car: 94 civic dx
i always do both anyways... its not that hard to pull out a fuse so i figure that it wouldn't hurt anyting to make sure that ecu is dead
» Site Navigation
» Home
 > FAQ
» Other Sites
