swapped an auto d16y7 in my manual car now erratic idle??
my car is 98 civic dx coupe, the old motor went, bought an 98 motor out of an auto civic, for 375 bucks, 92k miles. installed it, runs great but erratic idle. i used the wiring harness that came with the motor. so there are some wires left that are used for the auto transmission. well i took it to honda, and got it plugged in, and it says vaccum leak. there is no leak to be found, so i swapped the map sensor, still the same issue. honda says i pretty much have to swap my old harness back in because the auto trans harness will cause issues.
is there any other way around beside of having to replace the harness? what could be the other causes? bad throttle body gasket? or what? the mechanic checked it all for leak, found nothing.
is there some wire that needs to be jumped, or modfied?
