ok so to get the crank pully golt off I did the little trick of jaming a screw driver into the flywheel to spot it from sining.
but now when I go to put the flywheel dust cover back on the drivers side axle block the top of the dust shield form sliding in nicley.
I have tried to tap it in or turn the axle to make it go in but nothing so far, Ill mess with it some more tommorow but some tips would be GREAT
