Old 02-14-2007, 11:08 AM   #1 (permalink)
Car: 1997 Civic EX
honda12phoenix is an unknown quantity at this point
Angry tps sensor help
i think a lot of my bad idling is coming from by throttle position sensor, i was going to replace it but it looks as if it is part of the entire throttle body.
97 civic ex d16y8
am i going to have to replace the entire throttle body to replace it or does it come off. im not really positve on it.
honda12phoenix is offline
Old 02-14-2007, 01:08 PM   #2 (permalink)
klungemonger's Avatar
Car: 98 Civic DX hatch
You can buy one off Ebay new and replace it, but you really should make sure that that is the problem before going through the hassle.
klungemonger is offline
Old 02-14-2007, 07:06 PM   #3 (permalink)
HondatechAV6's Avatar
Car: 2000 Accord Lx V6
i seriously doubt the tps is causing a bad idle.
describe what is happening when the engine is hot and when it's cold.
explain why you think the tps is the cause.
realize i'm just here the help
I'm just a nice guy.
HondatechAV6 is offline
Old 02-15-2007, 11:17 AM   #4 (permalink)
Car: 1997 Civic EX
it will bounce up and down cold or warm dont matter
go from 1k to 2k keep doing it, cleaned out iacv but didnt help it at all
Old 02-15-2007, 03:18 PM   #5 (permalink)
Have you ruled out the possibility of any vacuum leaks?
Old 02-15-2007, 07:27 PM   #6 (permalink)
yeah, when it's fully warmed up, spray throttle cleaner at all vacuum lines, intake gasket, throttle body one section at a time, looking for a flare in rpm.
if you couldn't find a vacuum leak, do a search for idle problems.
Old 02-16-2007, 12:00 AM   #7 (permalink)
ThatGuy4life's Avatar
Car: 2000 Civic Si
Mods: built 2000 Integra Type R engine and tranny. Head is ported and polished, Crower rods, JE pistons Skunk2 stage 2 cams, REV Valves springs and retainers, skunk2 intake manifold, Act flywheel, RPS six puck sprung hub clutch, AEM cam gears, AEM fuel rail, STR cam seal, AEM V2 cold air intake, throttle body spacer, JDM ITR headers, APC catback exhaust
ThatGuy4life In the rep troposphereThatGuy4life In the rep troposphereThatGuy4life In the rep troposphereThatGuy4life In the rep troposphereThatGuy4life In the rep troposphereThatGuy4life In the rep troposphereThatGuy4life In the rep troposphereThatGuy4life In the rep troposphereThatGuy4life In the rep troposphereThatGuy4life In the rep troposphereThatGuy4life In the rep troposphere
If youve done any messing around with the throttle body, you may need to adjust the tps, do a search for how to and if you can't find it let me know i'll get it for you
Dam, did I just beat u in my Honda? Sure did, now your girl wants to get at me (True Story) "I built it, I drive it, your opinion doesnt matter. It doesn't have to be JDM it just has to be functional." http://www.texas-imports.com/forums/...referrerid=346
ThatGuy4life is offline
Old 02-16-2007, 12:49 AM   #8 (permalink)
jon
jon's Avatar
have you tried adjusting the idle screw? and as klunge said, vacuum leaks
silence is golden
but duct tape is silver
jon is offline
Old 02-16-2007, 10:39 AM   #9 (permalink)
GunMetal Member
slammed jdm's Avatar
Car: 2007 Mazdaspeed 3
Mods: 13.74 @ 107 with traction 12's are inevitable...
slammed jdm is just really niceslammed jdm is just really niceslammed jdm is just really niceslammed jdm is just really nice
1.) check your coolant to make sure it is full and if you've added any or have any leaks I would fix them and then bleed your coolant system...( your iacv low speed one on the bottom... I believe is controlled by coolant)
2.) if that doens't help or doesn't apply, go out under the hood and push the throttle (butterfly valve) closed see if the idle improves, if it does your throttle body needs taken off and cleaned, I've seen more than a few honda's with this very problem and people have tried changing everything from map sensors to intake manifolds, head gaskets, upper engine gaskets and valves only to find that the throttle body was dirty...
3.) also vacuum leaks as well like what has been said 2 times before. ( on your iacv there is a gold cover sometimes the gasket goes bad and they leak around there causing what you've described... - IATN )
good luck let us know what you find.
...god made turbo lag so v8's can get one last look at our tail lights...
Mitsubishi triple diamond certified, A.S.E.
Hyundai Bronze certified
Yes I am a Dick, and No I do not care what you think...
slammed jdm is offline
Old 02-16-2007, 11:43 AM   #10 (permalink)
Car: 1997 Civic EX
alright guys checked vaccum lines, all good. checked throttle body butterfly, as tight as tight could be, checked coolant its topped off nothing yet.
im unsure of adjusting the tps , help me out if you can
Old 02-16-2007, 12:27 PM   #11 (permalink)
jon
jon's Avatar
take a can of carb/brake clean, and start spraying around the intake manifold seals, t-body seal, vacuum hoses, basicly everything, and see if it affects the idle
silence is golden
jon is offline
Old 02-16-2007, 03:37 PM   #12 (permalink)
Car: 2000 Civic Si
http://www.integra.orcon.net.nz/tps
Old 02-16-2007, 06:44 PM   #13 (permalink)
ok, if all you checked is ok, i'd remove the black intake tubing and feel the lower port on the throttle body with your finger. it should have suction on a cold engine and no suction on a fully warmed up engine.
if your car is fully warmed up and you feel suction at that lower port, the fast idle valve is stuck open.
Old 03-04-2007, 09:49 PM   #14 (permalink)
SHOTTS27 will become famous soon enoughSHOTTS27 will become famous soon enough
I Have this!!
I have the same exact thing going down with my car. I have replaced the map sensor the IACV in fact this wekend I canged the manifold out for a skunk2 and I put new gaskets in as well, all lines are good no leaks in the vacuums, yet the idle still bounces go figure. I'll keep toyin with it, but I'm almost out of ideas.
SHOTTS27 is offline
Old 03-06-2007, 06:33 PM   #15 (permalink)
96civic3door's Avatar
Car: 00 Corvette 'Vert M6
Mods: Bolt ons and a tune, 12.68 at 112mph in the 1/4 mile
96civic3door Why haven't you checked into rep rehab yet?96civic3door Why haven't you checked into rep rehab yet?96civic3door Why haven't you checked into rep rehab yet?96civic3door Why haven't you checked into rep rehab yet?96civic3door Why haven't you checked into rep rehab yet?96civic3door Why haven't you checked into rep rehab yet?96civic3door Why haven't you checked into rep rehab yet?96civic3door Why haven't you checked into rep rehab yet?96civic3door Why haven't you checked into rep rehab yet?96civic3door Why haven't you checked into rep rehab yet?96civic3door Why haven't you checked into rep rehab yet?
I would about bet it is the TPS, does the car idle fine on start up untill you hit the gas?
Try it, when your car is cold start it up and do not touch the gas. I bet it idles fine untill you hit the gas.
C5, Full Exhaust(X pipe), K/N Cold Air, C6 Z51 Brake Upgrade, SLP Short Throw, CAGS eliminater
96civic3door is offline
