» Sponsors
» Sponsors
Old 11-23-2007, 01:53 PM   #1 (permalink)
Car: '97 Civic EX
Mods: Cold Air Intake, DCS Header, MagnaFlow Cat
Brian97EX is an unknown quantity at this point
Trouble w/ D16Y8 Throttle Body Spacer
I just installed a throttle body spacer in my Civic. I reconnected everything and when I started the car, it idled at about 2K rpm. After about five seconds, the idle began oscillating between 1 and 2K rpm. I drove it around for about ten minutes and seems to be fine while driving, but it still oscillates when idling. Why is this happening and how do I fix it?
Brian97EX is offline
Old 11-24-2007, 01:18 PM   #2 (permalink)
Car: '97 Civic EX
Angry Trouble w/ D16Y8 Throttle Body Spacer
OK I took the spacer out and reset the ECU. Throttle still pulses. Someone had posted in another forum about performing an "idle relearn". Anyone have any idea what this is and how to do it? I can't find any info...
Old 11-25-2007, 12:52 PM   #3 (permalink)
kommon_sense's Avatar
Car: 98 Civic Ex Coupe
Sounds like a vacuum leak. You may need to replace the tb gasket. The idle relearn procedure is posted in the forum stickies.
kommon_sense is offline
Old 11-26-2007, 08:16 AM   #4 (permalink)
Car: '97 Civic EX
Unhappy Idle still bouncing
Yesterday I took off the IACV and cleaned the hell out of it. When I put it back on, I still had the idle bounce. I bled the coolant and refilled the overflow and ran it for about twenty minutes. Still same problem. Then I took the 2P connector off of the IACV and the idle dropped to about 1500 rpm and bounced less. Driving to work this morning was real fun! Vacuum hoses are all good. I've got a new gasket on order. I'm hoping this will fix it because the gasket that came with the spacer looks suspect. Any other input?
BTW I looked through the stickies and couldn't find anything on "idle relearn" or "idle learn".
Old 11-26-2007, 09:39 AM   #5 (permalink)
Car: '97 Civic EX
idle reset
nevermind the btw. I found the reset procedure in the stickies.
Old 11-26-2007, 11:51 AM   #6 (permalink)
00BLACKSI's Avatar
Car: 1997 Hatch Cx
Mods: Mini me
00BLACKSI has a Rep problem00BLACKSI has a Rep problem00BLACKSI has a Rep problem00BLACKSI has a Rep problem00BLACKSI has a Rep problem00BLACKSI has a Rep problem00BLACKSI has a Rep problem00BLACKSI has a Rep problem00BLACKSI has a Rep problem00BLACKSI has a Rep problem00BLACKSI has a Rep problem
How did you end up making out? Did you notice any differences with this spacer? Was it worth it in other words?
Thanks
Peace
New Car 97 Silver CX hatchie GOT IT on 11.30.06:W00t
RIP 00 FBP Si Totaled on 02.11.06
RIP 95 Black HB Si Stolen and Totaled on 07.24.00
Originally Posted by WVU97GS-R
gotta keep it exciting bitches like i said before. i'm so jdm, both of my nuts are on the right side
Myspace
Vice President of "The Egg Hatching SHO Crew"
WANTED : 96-98 Ex Partsclick here to see shit I need email me eastbobdam@gmail.com
00BLACKSI is offline
Old 11-26-2007, 05:07 PM   #7 (permalink)
Car: '97 Civic EX
Angry Throttle body spacer
Don't waste your money. I still have a throttle pulse after removing the spacer. Not sure what's causing the pulse, but I think the spacer blocked the inlet for the IACV and tore it up. The gasket kit that came with it was also suspect and I am awaiting a new gasket to see if the gasket is causing the pulse. If not, I'll have to replace the IACV to the tune of about $180. So, in a nutshell, I am definitely NOT HAPPY with my spacer! Search the Civic forum for throttle body spacer if you decide to try one. I wish I had before I bought mine.
Old 11-27-2007, 06:26 PM   #8 (permalink)
HondatechAV6's Avatar
Car: 2000 Accord Lx V6
well, i wouldn't waste $180 if the problem is still there after you removethe spacer. i'd recommend getting it diagnosed if you are unsure about what's going on.
I'm just a nice guy.
HondatechAV6 is offline
Old 11-27-2007, 08:04 PM   #9 (permalink)
Car: '97 Civic EX
Thanks for your input guys! I put a new gasket in tonight and PRESTO! Perfect idle. Thanks HondatechAV6 and everyone that posted!
Old 12-01-2007, 10:19 PM   #10 (permalink)
4thGEN's Avatar
Car: 1991 Honda Civic Hatchback
Mods: D16A6-T
4thGEN is an unknown quantity at this point
the highest horsepower d's dont use throttle body spacers...
[img]http://www.fototime.com/ftweb/bin/ft.dll/standard?pictid={E9B51CD6-5177-4754-B278-B0E31B71865B}[img]
4thGEN is offline
Old 12-01-2007, 11:14 PM   #11 (permalink)
Car: '97 Civic EX
I don't have nor do I want the "highest horsepower d". Mine's a daily driver and I wanted the extra gas mileage.
Old 12-02-2007, 12:31 PM   #12 (permalink)
4thGEN's Avatar
Mods: D16A6-T
post the results when you get them.
4thGEN is offline
Old 12-02-2007, 12:39 PM   #13 (permalink)
Car: '97 Civic EX
Oh, I'm not using the spacer. I don't think the holes line up properly even though NOPI assured me that this is the spacer for my engine. I'm chalking it up to money poorly spent on a valuable learning experience.
