Old 04-24-2008, 10:54 PM   #1 (permalink)
Cheerioeg6's Avatar
Car: 92 civic H/b
Mods: front-gsr strut and tenzo r strut bar, Lower rear-spoon strut, tokico suspension, and rear disc brake
Cheerioeg6 is on a distinguished road
Tire VTEC not kicking in Major help*******
i just finished my car and vtec is not kicking in i removed the oil jack out of my d15b7 and wired my three wires (one is for oil pressure and the other is for vtec and last one is ground which i ground to the starters ground too...) need help to get my vtec kicking....
Cheerioeg6 is offline
Old 04-24-2008, 10:54 PM   #2 (permalink)
Cheerioeg6's Avatar
Car: 92 civic H/b
can anyone tell me or show me some pic too....
Old 04-24-2008, 11:15 PM   #3 (permalink)
Zinc is sad...just sadZinc is sad...just sadZinc is sad...just sadZinc is sad...just sadZinc is sad...just sadZinc is sad...just sadZinc is sad...just sadZinc is sad...just sadZinc is sad...just sadZinc is sad...just sadZinc is sad...just sad
D16A6 to D16Z6 Conversion..."Mini-Me"
Zinc is offline
Old 04-25-2008, 01:34 PM   #4 (permalink)
Cheerioeg6's Avatar
Car: 92 civic H/b
no a d15b7 with d16z6 head
Old 04-25-2008, 01:35 PM   #5 (permalink)
Cheerioeg6's Avatar
Car: 92 civic H/b
no as i said a d15b7 block with a d16z6 head
Old 04-25-2008, 01:53 PM   #6 (permalink)
then search a how to for that, they're everywhere. Google mini-me and you'll get 1000 sites with either the mini setup or austin powers.
There's nothing anyone can say to help you, if you say you removed the oil jets from the b15 block, and did the wiring properly, then you're just going to have to recheck your work. Maybe you have the wrong computer you need the d16z6 computer, or maybe your vtec solonoid is no good, or maybe you have no oil pressure. It can be a lot of things and without the car in front of you you can't check all these things.
here's a write up
Honda-Tech.com: Honda Civic/Del Sol (1992 - 2000): FAQ: D15 SOHC VTEC Mini-Me : Massive Write-Up (56k Goodbye)
Zinc is offline
Old 04-25-2008, 10:43 PM   #7 (permalink)
Cheerioeg6's Avatar
Car: 92 civic H/b
thanks....but i have a p28-A01 ecu.....does when wiring the vtec does it need a relay or can anyone help me on wiring the vtec
Old 04-25-2008, 11:00 PM   #8 (permalink)
Cheerioeg6's Avatar
Car: 92 civic H/b
can having high compression affect the vtec too...cause it compression at 220-240 ps
Old 04-26-2008, 02:59 PM   #9 (permalink)
civic_x_95's Avatar
Car: Former ED6 and EJ1 owner. I roll a Jeep for now... I like em topless and dirty!
civic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a lifecivic_x_95 You need a life
Damn dude your confusing the hell outta me with you rambling. Try using proper grammar please!
First off how do you know it's not working? VTEC on a SOHC isn't like a B Series where you can noticably hear and feel it kick in.
How are you trying to wire it in? Just re-pinning the ECU plugs? No it doesn't need a relay. Double check your wiring, and then check it again. Be sure to solder the connections rather than use tape.
Unless your 88-91 CIvic/CRX is RHD and the 4&5 letters in your VIN are "EF", you DONT have a EF.
civic_x_95 is offline
Old 04-26-2008, 10:46 PM   #10 (permalink)
Cheerioeg6's Avatar
Car: 92 civic H/b
so your suggesting to rewire my wires and ok
Old 04-26-2008, 10:47 PM   #11 (permalink)
Cheerioeg6's Avatar
Car: 92 civic H/b
my vtec works just that it not kicking in at 4300 rpm and up i can't feel it or does it need to reveal higher ....
Old 04-27-2008, 01:15 AM   #12 (permalink)
reveal how you got over the border buds.
Zinc is offline
Old 04-27-2008, 12:44 PM   #13 (permalink)
civic_x_95's Avatar
VTEC doesn't even kick in until 4200 on a SOHC...
Old 04-27-2008, 11:39 PM   #14 (permalink)
Cheerioeg6's Avatar
Car: 92 civic H/b
it does engage its still the same when it get to it or even more.....
Old 04-28-2008, 05:15 PM   #15 (permalink)
civic_x_95's Avatar
Say what? Not entirely sure I understand what your saying... ok I don't understand what your saying. But I promise you that your VTEC does not engage until 4200r's unless you have an controller installed and have it set to a lower RPM.
Heres something you can do... without frying anything, get a wire schematic for your ECU, find the lead from the ECU to the VTEC selonoid, tap in a LED (radio shack, make sure its 12v) light into the wire coming from the ECU right at the selonoid, then run the light inside to where you can see it while driving. Now when your driving and VTEC engages the light will light up. If it doesn't then you either have a bad ECU or bad wiring.
Now, incase you didn't know, VTEC does not engage unless you are moving, so testing it while sitting still will not work.
