Old 12-12-2006, 09:05 AM   #1 (permalink)
Car: '89 Civic DX hatchback
legacyo13 is on a distinguished road
Wiring help
I'm swapping parts on my d15b2, I'm throwing a y7 head and an si tranny. I was wondering how the wiring would be to wire up an si ecu. I've searched and never got a real clear answer. So any help would be nice. Thanks in advance.
legacyo13 is offline
Old 12-12-2006, 09:31 AM   #2 (permalink)
Lifeless Ninja
98civcEK's Avatar
Car: 98 Civic DX
the only probelm would be the dizzy wiring, assuming your gonna use the IM off your surrent motor.
you need to remove the wiring from the inside of the y7 dizzy and put the wiring from inside yours into it. thats the only wiring thing that should be different.
98civcEK is offline
Old 12-20-2006, 12:38 PM   #3 (permalink)
Wiringtech is an unknown quantity at this point
You'll need to change from DPFI to MPFI. Then you'll need to use a 88-91 Si distributor. You'll also need to get 88-91 injectors from an Si. Here's a link to wiring:
http://www.angelfire.com/d20/hcivic88/dx-siwiring.html
http://WWW.HONDAPARTSHERO.COM
Distributor Adaptor $25
VTEC Oil Pressure Switch $25
4 wire O2 ext. harness $20
4 wire O2 harness $20
2 wire IACV harness $10
VTEC Swap Subharness OBD0, OBD1, OBD2/2b $25
Single plug wiring, shielding, and ECU pin $10
Knock, VTEC solenoid and pressure switch, IAB wiring harnesses
Mini Me Harness OBD1/OBD2 $20
HONDAPARTSHERO@AOL.COM
Wiringtech is offline
Old 12-21-2006, 09:38 AM   #4 (permalink)
IISaiNtII's Avatar
why are you wanting to run a vtec ecu on a nonvtec head?
-Proverbs 16:31
- Martina Navratilova
IISaiNtII is offline
Old 12-21-2006, 01:00 PM   #5 (permalink)
The d-series si wasn't vtec'd. I'm looking into wiring a pm6 up which is a non-vtec si ecu.
Old 12-21-2006, 03:04 PM   #6 (permalink)
IISaiNtII's Avatar
ah, yes, i forget about that one.
wasn't that a dohc motor though? if so, that ecu won't work.
-Proverbs 16:31
Old 12-21-2006, 08:16 PM   #7 (permalink)
I believe it came with both. I'm not sure, but it's two different ecu's form what I've seen. But my friend had one on his car before he wrecked it. But he's got 3 on him. That's his second ef this year.
