Old 05-14-2002, 12:33 PM   #1 (permalink)
zcsohc is an unknown quantity at this point
10 psi on a SOHC anyone is it safe
Thinking about upping my boost from 8 psi to 10 it will be well tuned retarded timing underboost and plently of fuel also I can run race gas. Would this be the stupid thing to do for an everyday driver? Anyone done this and had there motor last a couple of years? Standard Internals my setup is in the signature. Thanks
zcsohc is offline
Old 05-14-2002, 12:53 PM   #2 (permalink)
b18c5turbo is an unknown quantity at this point
i recommend a block guard
b18c5turbo is offline
Old 05-14-2002, 06:49 PM   #3 (permalink)
Car: 2002 civic si hatchback
themi6group is an unknown quantity at this point
10psi won't be a problem as long as you manage your fuel and tuning you'll be straight. and of course regular maintenance. your engine will outlast your turbo if care is given.
timing is everything
themi6group is offline
Old 05-14-2002, 10:03 PM   #4 (permalink)
Only thing bothering me is the rods they are meant to be pretty weak, you guys know anyone who runs 10 psi or have you personally ?? Thanks
zcsohc is offline
Old 05-15-2002, 02:06 AM   #5 (permalink)
peeps with f-max kits run 10psi daily on stock. i've ran it here and there but the rod strength concerns are not the most important at that psi. it's fuel.
Old 05-15-2002, 09:05 AM   #6 (permalink)
Car: 1979 Honda Civic CVCC
Mods: Why mess up a perfect vehicle?
ashstudly is an unknown quantity at this point
I have installed a turbo on a '98 civic with upgraded injectors, fuel pump, and fuel management system. Also was intercooled. So far he has gone about 25,000 miles (does a ton of driving) and has not had any problems. I believe that and intercooled turbo kit with a fuel management system would do you just fine without the rest of the stuff. Never installed one though with just management so I don't know if the stock fuel system can handle it. I'll see if I can get a hold of the guy with the turbo I installed so you can ask him how he likes it.
Why mess with an already perfect vehicle?
ashstudly is offline
Old 05-15-2002, 10:32 AM   #7 (permalink)
Car: student
99SIVTEC is an unknown quantity at this point
I wouldn't bother with a block guard at 10 psi. I would however watch your timing and fuel very closely. The first thing that will go on a SOHC is the rings. If you get any kind of prolonged detonation the rings will be shot in no time. Just get it tuned and be a bit on the safe side even if you ahve to sacrifice a few hp...
www.highaltitudeimports.com
www.club18t.com
99SIVTEC is offline
Old 05-15-2002, 11:53 AM   #8 (permalink)
AztecEJ is an unknown quantity at this point
Read the posts I made in this threadOthen then ignition and FMU what mods are needed for 7psi daily driving? about setting your car up to run 10psi safely on a sohc. Its called the afc hack(well its not really a hack anymore if you do it the way I describe it) but check it out its very useful stuff
Sohc Power(I know this pic is big, I'm tryin to fix it )
.....boostin' soon
AztecEJ is offline
Old 05-15-2002, 12:44 PM   #9 (permalink)
Thanks for your replys I have a much better tuning device then a AFC, called a Turbo link it has its own map sensor, retards timing under boost, and adds more fuel using 3 extra injectors. I was just speaking to the tuner and he said that I won't have to get it retuned to run more boost say's the turbo link will see the extra boost and add fuel accordingly it was originally tuned for 7psi. So I might go and get myself a manual boost controller
zcsohc is offline
