it's been a long time since i have posted, but im upgrading my turbo set up, so i figured i'd post up some details ... and i am bored, so enjoy. and by the way the car is a 2000 civic Si with full interior, cruise control, etc
NEW SETUP
ls/vtec 85mm bore, CTR cams, VictorX intake manifold
GT3582r on Topmount manifold
we are expecting 630whp +/- on c16.
im hoping to run around 10.5 @ 140 roughly
i'll post up some pictures when it's finished, should be done in about a week or 2
2000 Civic Si ls/vtec
592whp @ 22psi
RLZ ENGINEering
damn nice setup, post some pics of it. and when did u get spool on ur 60-1, im bout to run the same turbo n just curious of when people were gettin full spool
NEW SETUP
Nice setup, I was just wondering what size injectors you were using? My setup is really similar, and will be using a T3/60-1 turbo in november after the new engine is finished being broken in. My power goal was the same also 400whp at what I was estimating to be 18psi. Your 1/4m times are great, what kind of 60' were you getting? Do you have anything in the traction department? I will be getting a full-race turbo kit and their traction bar at the same time my goal was 11's also. Great setup and keep us posted on the new build.
B18 with a B16 head
70mm throttle body-Skunk2 Intake Manifold
1000cc Injectors-Eagle rods-CP 9:1 pistons
ACT 12lb flywheel-ACT 6 puck sprung clutch
Quaife LSD-Full Race Traction Bar
Full Race t3/60-1 turbo kit-Ram Horn Manifold
205/60/14 BF Drag Radials
331HP at 13psi Cams and more boost to come
Currently looking for some ITR or CTR cams, PM me if you have them.
For sale or Trade. Thermal catback 2 1/4" exhaust.
Clutchmasters stage 3 kevlar clutch and pressure plate.
the 60-1, which had the upgraded stage 5 wheel made full boost at around 4500rpm. that was on an ls/vtec 84mm (2.0L). it was incredibly fast.
on the previous set up i was using rc 650cc, but now we are going 1000cc. dont worry about engine break in. rings need less than 50 miles to seat. i have low c/r @ 8.8:1 so i can make 18psi on pump with no worries .... that 1/4 time was back when the car was on 22" slicks, stock differential and stock axles w/ a 1.75 60' time. since then i have upgraded to 24.5" slicks and have a quaiffe. still stock axles til i break them. as for traction, none, just coilovers to lower the car a little bit.
592whp @ 22psi
RLZ ENGINEering
dynoed the car on pump gas ... 93 octane made 496whp.
going to do race this weekend
that turbo wont make 630 i've tried especially with a t3 hot side t4 you have a better chance though of making that
"BALLS" is coming home late after a night out with the guys smelling of perfume and beer, lipstick on your collar, slapping your wife on the ass and having the balls to say, "You're next!"
9.70@148 built bottom end w/stock head
10.40@136 bone stock gsr motor
aem tuned by me
gt35r
full race kit---old setup=junk thank god i threw it away in the garbage www.turboelements.com
not to be a dick, but that turbo is very capable of 630whp. and if you couldnt do it, then that doesnt mean it cant be done.
there have been several cars to make this kind of power with the gt35r @ RLZ on a dynapack 3000, which typically reads low compared to other dynos.
624whp @ 24psi
651whp @ 27psi
i have already made 496whp on pump gas (@ only 8300rpm) with a conservative afr and retarded timing. with c16 and advanced timing, revving to 9500rpm, 600 will be simple.
i'll post my dyno sheet when it makes the power i said
if you are talking about the gt35r with the .63 a/r exhaust side, then i'd say 600+ wont happen. this turbo has the .82 a/r exhaust. power wont be a problem, traction will
592whp @ 22psi
RLZ ENGINEering
True . gt35r is very capiable of 600whp. jeff evans runs this turbo on a stock gsr motor and pulls i think 300whp! he's also one if the best tuners i know. Well not know but what i herd of. lol Hey man maybe you should consider getting a full race traction bar to help you with those 60 footers.
yes it's crazy on the street. from a 60 roll in 3rd gear ..... if i get the DRs hot enough they hook pretty good! it's moving right now; cant wait to do some high boost
592whp @ 22psi
RLZ ENGINEering
