Old 03-04-2004, 11:40 AM   #1 (permalink)
Car: 2001 neon r/t
girlyon18s is an unknown quantity at this point
AFC Hack
I always hear about this. But can someone please explain? I hear you can use it for a boost controller also?
01 turbo neon R/T-over 300 horsies :evil
04 civic coupe VP
girlyon18s is offline
Old 03-04-2004, 11:44 AM   #2 (permalink)
Car: 98 Lude
Mods: some
yellowd16 is a splendid one to beholdyellowd16 is a splendid one to beholdyellowd16 is a splendid one to beholdyellowd16 is a splendid one to beholdyellowd16 is a splendid one to beholdyellowd16 is a splendid one to beholdyellowd16 is a splendid one to beholdyellowd16 is a splendid one to behold
Super AFC- is for boosted cars
yellowd16 is offline
Old 03-04-2004, 11:52 AM   #3 (permalink)
Car: 2001 neon r/t
actually the SAFC is for NA/turbo.
I had it on my na civic and now it's on my turbo neon. I'm not looking for a answer like that. Maybe someone that knows can explain?
04 civic coupe VP
Old 03-04-2004, 12:00 PM   #4 (permalink)
Car: 98 Lude
Mods: some
http://www.infinitracing.com/SUPER_AVC_TYPE_R.html
Old 03-04-2004, 12:07 PM   #5 (permalink)
TheTurboDan is an unknown quantity at this point
the safc will not control boost at all, only injector pulses
TheTurboDan is offline
Old 03-04-2004, 12:08 PM   #6 (permalink)
Car: 98 Lude
Mods: some
yea, dat was my bad, thought of the wrong one
Old 03-04-2004, 12:11 PM   #7 (permalink)
Car: 98 Lude
Mods: some
Re: AFC Hack
hey did u look at the web page i put up?
Old 03-04-2004, 11:40 PM   #8 (permalink)
Car: 1994 Civic Ex (the $800 model ;))
Mods: yea... about that
JoeCivic is an unknown quantity at this point
Here's how it works. The map sensor shows ecu boost... ecu takes a shit. In order to prevent this one uses the hack:
1. use injectors that are about..30-40% larger than needed... in most cases 450s work.
2. Set afc to -30-40%
the afc works by altering the signal from the map sensor to the ECU. To lower the fuel, it lowers the map sensor reading, to increase fuel, it increases the reading. So, by having injectors that are larger than you need, it allows you to cut fuel back by a great enough margin that it reduces the boost signal is converted to one that the ECU interperates as vacuume.
This way you still get a pretty well regulated fuel curve (ecu recievs map sensor signal in proportion to actual map... only lowered enough that it doesn't throw a cel.
Make sense?
BEFORE:
CURRENT:
JoeCivic is offline
Old 03-05-2004, 01:34 AM   #9 (permalink)
Lifeless Ninja
civperc's Avatar
Lauren - check out this page: http://www.thedropshop.tv/vafc.htm
Advertise on Superhonda
civperc is offline
Old 03-05-2004, 09:31 AM   #10 (permalink)
Car: 2001 neon r/t
Originally posted by JoeCivic
Make sense?
Now this makes sense. I kept on hearing about this. I had this problem for a long time with the map. I made a device(radioshack owns)that tricks the map sensor also to keep the voltage from going above 4.5(my car cuts out around there). So same idea then. Thanks for the help guys.
04 civic coupe VP
Old 03-09-2004, 03:48 PM   #11 (permalink)
Wadzii22 is an unknown quantity at this point
Why the Vafc hack is not good
read that..... then understand what the vafc does, it rescales the fuel AND ign maps to work on a different scale.
it sounds like a good idea at first, it work well for the fuel, but it completly clusterfucks the ign maps
Offical AEM Factory Trained EMS tuner
www.c a r o l i n a h o n d a s.com
www.eurospeedperformance.com
Wadzii22 is offline
