Old 03-27-2002, 05:17 PM   #1 (permalink)
outlawtas is an unknown quantity at this point
Airflow Question...
Using the LPM formula, you can determine airflow of a given engine, not under boost.
so,
Flow = Displacement x VE x (rpm/2)
I'm trying to find the flow rate of a b18b engine, when I came across a question...this is what happens when you fill out the formula...
Flow = 1.8 x .85 x (6000/2)
Flow = 1.8 x .85 x 3000
Flow = 4590 LPM
1 CFM = 28.317 LPM, ergo 4590 LPM = 162.09 CFM
Now, my question to you is, does airflow rate determine power? Because, if you would see that a B18b1, B18c1 and B18c5 all have the same airflow rate...so why does one have more power than the other? thanks...
outlawtas is offline
Old 03-28-2002, 07:59 AM   #2 (permalink)
slickhonda is an unknown quantity at this point
what is VE?
slickhonda is offline
Old 03-28-2002, 11:35 PM   #3 (permalink)
volumetric efficiency....lol
Old 03-29-2002, 08:51 PM   #4 (permalink)
oh, yeah...that was dumb of me....so obviously there is more to the power an engine can produce then just flow. Flow is big but there are other variables like efficiency of the engine which is linked to compression ratios and combustion chamber designs.
Old 03-30-2002, 02:38 AM   #5 (permalink)
Honda_Guy's Avatar
Car: '68 Mustang notchback, '84 Mustang SVO
Mods: More than can feasibly fit on this line
Honda_Guy is infamous around these partsHonda_Guy is infamous around these partsHonda_Guy is infamous around these partsHonda_Guy is infamous around these partsHonda_Guy is infamous around these partsHonda_Guy is infamous around these partsHonda_Guy is infamous around these partsHonda_Guy is infamous around these partsHonda_Guy is infamous around these partsHonda_Guy is infamous around these partsHonda_Guy is infamous around these parts
First, the B18C1 and B18C5 have higher compression, making them more thermally efficient. Second, the B18B, B18C1, and B18C5 do not each have the same volumetric efficiency, so you would have different numbers to calculate into your formula.
1968 Mustang Notchback-Roller cam 302, Edelbrock 60379s, Hooker Comps, Crane 2031, Duraspark, forged pistons, Weiand X-Celerator, Holley 650DP, Fidanza AL fly, RAM clutch, Toploader, Comp Plus, McLeod bell, Mopar 15x7s.
1984 Mustang SVO- stock with Koni susp. & 2.3L turbo with an underrated 175hp/215tq.
'95 XR600R-yoshi header/muff, 200W stator.
Honda_Guy is offline
Old 03-31-2002, 01:08 AM   #6 (permalink)
thanks...out of curiousty, how come Honda_Guy is driving a mustang LOL?
anyways..I understand now, it's so simple. They both flow the same amount of air, but some compress that air more, maybe are less restrictive in the exhaust ports and intake ports just simple stuff
thanks
Old 03-31-2002, 02:09 PM   #7 (permalink)
neophyte is an unknown quantity at this point
anyone know a page or anything that has the various VE's for different hondas, or nissans? While I was trying to match a turbo for a b16 with a compressor map I came across a guy who had plotted the different VE's at different rpms of his mitsu eclipse motor across a compressor map.
neophyte is offline
Old 04-01-2002, 11:34 PM   #8 (permalink)
Honda_Guy's Avatar
Well, I've been a Ford guy all along. My first car was a '65 Mustang, then I decided to try out the imports for a while in the form of a 91 Civic hatchback. I wanted to go faster, but I would have to spend alot of money I didnt have to make it quick(did I menton it was an STD? 1.5L, 4 speed, dual point ignition, etc), plus the CA smog hassle. The 5.0 was just more economical for me. Sometimes its a little awkward being on SHO with a Mustang in my sig, but I'm into anything with an engine so its all good.
thanks
Right. Comparing the B18B1 and the B18C5, the C5 has mild portwork and matching cams, so it is more volmetrically efficient than the B1. It also has higher compression, making it more thermally efficient. That why the C5 has 195hp compared to the B1's 142(?), even though they are both 1.8L.
Old 04-02-2002, 08:33 AM   #9 (permalink)
yup exactly...hand ported
Old 04-02-2002, 03:22 PM   #10 (permalink)
Car: '96 GS-R
Mods: See my sig!
Nikolai is an unknown quantity at this point
The B18C1 and C5 motors are MUCH more volumetrically effecient, especially at higher RPM's, where peak power is important (thank you high profile VTEC cam).
Speaking of higher RPM's, your figures also were for a 6000 RPM redline, as opposed to 8,100 or 8,500. If you change that factor, then that's 30% more air alone, in the case of the B18C5.
Also, the effects of higher compression do not increase linearly, and though they are a factor, it's not as important when comparing B18b/b18c1/b18c5.
Nick
Nikolai is offline
Old 04-03-2002, 01:19 PM   #11 (permalink)
Port crossdirectional width is narrower on the C5 giving a higher intake velocity flow enabling it to make higher rpm power. The intake manifold primaries are shorter and straighter for a higher rpm power band. Exhaust primaries are longer for higher rpm power.
C1's manifold has 60% more surface area than the C5. More surface area the more 'drag' and less velocity. C1 and C5 for instance produce about the same power at 6K rpm. The C5 glows in the 7.5-8.5k range. The B1's ports aren't designed from the factory to have enough flow velocity to support flow at that rpm. The diameter of the intake should have an area that is 25% larger than the TB port area to give proper flow velocity. Pop the hood on the Ls and an R and see which is larger (in comparison to the TB).
Dr Drew is offline
