Old 02-26-2002, 07:47 PM   #1 (permalink)
rice4life is an unknown quantity at this point
anyone has turbo jdm sir B16a
where did you mount the 02 sensors? did you use both O2s or just one. don't they have to be close to the head to get enough heat to work properly and don't they have to sample air from 1-4cyl and 2-3cyl for it to run properly. What kit do you have and are you running any aftermarket computer with it?
91 CRX si, B16a with LSD YS1, Drag Gen3, 13.59@102mph at 5psi.
rice4life is offline
Old 02-26-2002, 07:48 PM   #2 (permalink)
TurboJDM is an unknown quantity at this point
With the Hondata and other fuel management systems you wont have any problems with o2 sensor and check engine lights... more the likely you will get a check engine light with the turbo if you have a stock ecu...
TurboJDM is offline
Old 02-26-2002, 11:06 PM   #3 (permalink)
does hondata makes stuff for pr3 ecu(nonOBD). i was on there website and saw that they only make stuff for OBD1.
Old 02-27-2002, 02:53 AM   #4 (permalink)
not sure but a good question ... call hondata and find out and please post what they say here.. thanks.
TurboJDM is offline
Old 02-27-2002, 03:16 AM   #5 (permalink)
Car: 1988 CRX Si
Mods: B16A, YS1 Tranny, lower compression pistons, turbo on the way
silverkorn is an unknown quantity at this point
yes hondata will work with a non-OBD, and thats from hondata and a dealer
with the hondata system though you have to use two 02 sensors. you cant just run a closed loop, atleast thats what i got from their fourm section of their website. very helpful.
http://www.hondata.com/cgi-bin/yabb/YaBB.cgi
'88 CRX Si w/ B16 Click here for mods
silverkorn is offline
Old 03-03-2002, 04:33 PM   #6 (permalink)
blackteg is an unknown quantity at this point
I've got the same problem I dont know where to mount the second 02 sensor, any advise?
94 integra rs (black)
B16a stroked to 1.8l
je pistons, crower rods
str drag manifold, str block saver knife edge crank
6.5lb flywheel, act clutch
upgraded injectors, fuel regulator
msd 6AL, 8.5mm wires, blaster coil
drag III kit, Direct Port 75 shot
PR3 ecu
3inch, apex N1
ferrea valves
crower springs tit. retainers
blackteg is offline
Old 03-03-2002, 05:21 PM   #7 (permalink)
it depends what ecu you are running. OBDII use 2 heated O2 sensor. one infront of cat and other one behind the cat. pr3 use 2 none heated O2 sensor and are mounted on the header on the secondary pipe.
Old 03-03-2002, 05:33 PM   #8 (permalink)
I just looked at my ecu and it says pr3, I have one sensor on the downpipe I think, but the other wire is just hanging in the engine compartment I dont know where it would go
PR3 ecu
3inch, apex N1
ferrea valves
blackteg is offline
Old 03-03-2002, 05:46 PM   #9 (permalink)
i have heard some people put the second O2 sensor next to the other O2 sensor. or you could just tap the other wire to the same 02 sensor that is one there now so both O2 wire are on the same O2 sensor.
Old 03-03-2002, 05:50 PM   #10 (permalink)
Which would work better tapping in to the other sensor or making a place for the second o2 sensor?
PR3 ecu
3inch, apex N1
ferrea valves
blackteg is offline
Old 03-03-2002, 06:04 PM   #11 (permalink)
tapping into other sensor would be easier. put other sensor in would be samething as tapping into other sensor because both sensor are in the same area and should have same reading. original placing for the 2 O2s are on cylinder 1-4 and 2-3, where the 2 sensors would have different reading. i have stock b16 header now with 2 sensors and when i swith the wires around my car runs like crap, thats why i want to know where to mount the O2s when i get turbo. you could tap into the other O2s and let me know how the car runs.
Old 03-03-2002, 06:23 PM   #12 (permalink)
I'll try just tapping into the other sensor I'll let you know how it runs.
Thanks for the help
brandon
PR3 ecu
3inch, apex N1
ferrea valves
blackteg is offline
Old 03-04-2002, 07:02 PM   #13 (permalink)
Car: 1989 CRX Si
Mods: B16@28psi, get the point?
CRXType-R is an unknown quantity at this point
How did it run ???
Turbo B16 CRX Si @ 28psi. More to say have you?
CRXType-R is offline
Old 03-04-2002, 10:01 PM   #14 (permalink)
I just decided to get a ECG Electronics Test Pipe 02 Simulator
Utilizes a RISC processor to exactly simulate the oxygen sensor outputs from the catalytic converter. CEL-free guaranteed! The Sim computes various vehicle sensor parameters in real-time to mimic the oxygen sensor outputs. No more check engine lights!
find it at www.importparts.com and let me know what you think(its only 39.99, better to do it the right way I think)
PR3 ecu
3inch, apex N1
ferrea valves
blackteg is offline
Old 03-05-2002, 07:09 AM   #15 (permalink)
Car: 1989 CRX Si
I do not understand what the thing is about...you do need a O2 sensor to get some kind of reading uh ??
