Alright a quick run down of my take on all of this.
The Apexi N1 is loud! And the turbo version is only the muffler, you'd have to make custom piping.
Apexi WS, well, as said above, not straight through = no good.
As far as bolt ons go, the best one I find is the Greddy EVO. I did research on this for quite awhile before taking off my 5zigen fireball and replacing it with the Greddy EVO. the EVO goes from 60-70mm, that's 2.25 inches to 2.75 inches, close enough to 3 inches. Since you are boosting at low levels, you should be fine. If you go anymore than 2.25 inches at cat, you have to replace your stock cat also, it just won't bolt on. Most other bolt-on cat-backs are either straight through 2.25 or 2.25-> 2.5. So EVO is the best choice.
Now the best part, the EVO comes with a HUGE ASS canister than silences the exhaust like crazy, the only time I hear something is if I'm punching it past 5k rpm, and even then it's a deep groan.
Go with the EVO, sure it's a bit pricy. But it's well worth the money! The quality simply... perfection.
http://www.londonautoclub.org
Image:
17x7.5 Konig Impact J-Spec;
Performance:
