Old 05-31-2002, 02:42 PM   #1 (permalink)
drkn4n is an unknown quantity at this point
benefits or bigger front mount intercooler??
i am thinking bout purchasing a front mount intercooler from greedy the real big ones i just wanted to know whats the benefits of purchasing one of these???
99 Gsr
Revhard Stage II turbo kit
Delta Waste Gate
Greddy Type S BOV
Spearco Intercooler
Turbonetics t3t4
Inline Pro Head Gasket
440 cc RC Injectors
Fuel Regulator
Fuel Pump
AFC
Koni Yellows
STR Intake
drkn4n is offline
Old 05-31-2002, 02:54 PM   #2 (permalink)
Car: Student
FBP Si 2000 is an unknown quantity at this point
Don't like you Spearco IC anymore? I guess one of the benefit of a bigger fmic is the efficiency of handling high boost.
'00 FBP Si
FBP Si 2000 is offline
Old 05-31-2002, 04:20 PM   #3 (permalink)
Car: 4 paper routes and work at D n B supply
Mods: not enough money to do everything I want to do with it. They say money makes the world go round!
Blaze is infamous around these partsBlaze is infamous around these partsBlaze is infamous around these partsBlaze is infamous around these partsBlaze is infamous around these partsBlaze is infamous around these partsBlaze is infamous around these partsBlaze is infamous around these partsBlaze is infamous around these partsBlaze is infamous around these partsBlaze is infamous around these parts
Colder intake temp= more HP. nuff said. Is it going to be water-to-air or just air-air?
Blaze
91 Honda CRX DX JDM B20Z
(who knows when I'll install it I have all the parts just need the time!)
www.geocities.com/extremeist45
B and D series Junk for Sale
Dude I smoked your secret stash above your door!
Dude, that was my missletoe.
Oh, It did give me a wired buzz.
Blaze is offline
Old 05-31-2002, 05:50 PM   #4 (permalink)
Car: 95 Teg
Mods: turbo, and body kit, and a paint job no one has in this world
therumbligteg is an unknown quantity at this point
Just look into water-to-air, you will thank me if you get it, their is no campasison between the two, water to air is better period.
Rumble on
therumbligteg is offline
Old 05-31-2002, 06:00 PM   #5 (permalink)
" Water to air is better. period" Word , do you guys know where i could pick one up cheap?
e-mail if ya got a link to somewhere or somthin,
extremeist45@hotmail.com
Blaze
Blaze is offline
Old 06-01-2002, 09:35 AM   #6 (permalink)
jordan is an unknown quantity at this point
This is firsthand info. My brother had a typhoon. 4.6 ltr turbocharged gmc blazer. It had a water to air aftercooler on it, and driving only 45 minutes would heat soak the aftercooler so bad you almost couldn't touch it. When we went to the track he would have to let it sit for at least an hour with water and ice in it to cool it down. The only reason, you would want a water to air is for drag racing only. that is it.
jordan is offline
Old 06-01-2002, 09:44 AM   #7 (permalink)
Car: '97 Civic EX
N2O'dturbocivic is an unknown quantity at this point
i agree, i would stick to air to air if its a daily driven car. I have the type 24 intercooler from greddy and i love it. its huge. personally my engine doesn't really need it because i am only running around 8 psi, if you are running more than 10 get the big one and it will help you out more than the spearco one because the lines are thicker on the greddy one. its nice and shinny too! expencive though, but if that doesn't matter go for it, but only if your running more than 10 psi
"You can't get power out of a SOHC?!" "Dear lord he got power out of the SOHC!!"
N2O'dturbocivic is offline
Old 06-01-2002, 10:10 AM   #8 (permalink)
Car: 95 Teg
Did your brother have a seprate radiator for his aftercooler, or did he just share the water supply with the cars radiator. If they are only for drag racing how come some Subaru's come with them stock. Air to Air aftercoolers are only effective at high speeds, and I am not saying that they suck, I am just saying water to air are more effecitive.
Rumble on
Old 06-01-2002, 08:49 PM   #9 (permalink)
GunMetal Member
BoostedRex is an unknown quantity at this point
if the ic is too big for the turbo you will loose power, and efficiency, because of loss of pressure etc.... i heard it somewhere, i would do some research on it before buying the biggest one greddy has to offer.
BoostedRex is offline
Old 06-01-2002, 09:56 PM   #10 (permalink)
Car: 95 Teg
You are right BoostedRex, if the aftercooler is too big it results in power loss, so get one in accordenc to the amount of boost you are running.
Rumble on
Old 06-02-2002, 12:48 AM   #11 (permalink)
i am running at 13lbs right now daily driven??would it benefit me?
99 Gsr
Delta Waste Gate
Greddy Type S BOV
Spearco Intercooler
Turbonetics t3t4
440 cc RC Injectors
Fuel Regulator
Fuel Pump
AFC
Koni Yellows
STR Intake
drkn4n is offline
Old 06-02-2002, 02:50 PM   #12 (permalink)
Car: 1988 honda crx
Mods: T3 turbo 22lbs boost, custom intake/header/exhaust Tec II comp. 65mm throttle body, and a few extra goodies
bmilescrx is an unknown quantity at this point
ic sizing
you all have forgot a very important piece of the puzzle, Its not just about how much boost you run, but about how much air flow you run, i.c. sizing is based on air flow requirements, not just psi ratings.
your best bet is to look up on a compressor map for the turbo you have and find the flow rating for the psi your running , and then calculate how much air your compressor can run, then with that number you can find out how much (theoridical) hp you are making.
roughly 1 lb of air =10hp so if you compressor can run 30lbs of air @ 15psi of boost you would want to buy a ic that is rated for roughly 300hp , granted you are not running that much air (more like (22lbs of air @10psi) but its much better to have to big of i.c. than too little of an i.c..(within reason)
I have personally gave myself about 100hp buffer on intercooler sizing, it give you alittle room for future upgrades and will prevent heat soak from comming on too quick. however if your turbo will run 40lbs of air and your currently running 20lbs of air and have no intent on running 40lbs, my recomendation is to get an i.c. that is good for 30lbs of air/or (300hp). you get the idea just do the math and youll be all right
good luck
Laters
bmilescrx@yahoo.com
Who said there is no replacement for displacement? Turbo Anyone?
NEW T3/T4 Turbos, wastegates, intercoolers for sale, email me @ bmilescrx@yahoo.com if interested
bmilescrx is offline
