Old 07-24-2005, 09:48 PM   #1 (permalink)
Car: 89 SI
89CivicHatch Needs to go outside once in awhile89CivicHatch Needs to go outside once in awhile89CivicHatch Needs to go outside once in awhile89CivicHatch Needs to go outside once in awhile89CivicHatch Needs to go outside once in awhile89CivicHatch Needs to go outside once in awhile89CivicHatch Needs to go outside once in awhile89CivicHatch Needs to go outside once in awhile89CivicHatch Needs to go outside once in awhile89CivicHatch Needs to go outside once in awhile89CivicHatch Needs to go outside once in awhile
Boost
alright guys i just pick up my first turbo kit, i don't want anything all i want is 6 up to 8 pounds of boost just so i can see what it like! This well be fine on the interals here is the list i got so far, any advice would help out someway. i got the turbo kit for 700 dollars my buddy really needed the money so i pick it up.
-fuel pump
-injectors(what would you prefer)
-b16 (lsd tranny)
-flywheel
-clutch
-fuel rail
-fuel regulator
-head gasket(how thick should i go, where can i get one acura, honda?)
-water pump
-new timing belt
-itr valvetrain
anything else that would help me to get more fuel well i be fine? o ya forgot to add something as soon as the turbo kit and everything put on it getting tuned right away! thanks
Live Life one Step at a Time!!!!1
89CivicHatch is offline
Old 07-24-2005, 10:27 PM   #2 (permalink)
gurusan's Avatar
umm what?
Your english is HORRIBLE.
Learn to type. What exactly are you asking?
uɐsnɹnƃgurusan
Teal Civic Sold: 08/31/2006
FOLD FOR SHO! TEAM 54075
folding@home
gurusan is offline
Old 07-24-2005, 10:52 PM   #3 (permalink)
Car: 89 SI
Originally Posted by gurusan
umm what?
sorry well i be fine? Well the motor hold it own weight? i'm getting a compression test before and after the boost, to see if well handle it
Old 07-24-2005, 11:02 PM   #4 (permalink)
Car: 2006 Mitsubishi Lancer Evolution IX
Mods: Stock
xtremefusion is sad...just sadxtremefusion is sad...just sadxtremefusion is sad...just sadxtremefusion is sad...just sadxtremefusion is sad...just sadxtremefusion is sad...just sadxtremefusion is sad...just sadxtremefusion is sad...just sadxtremefusion is sad...just sadxtremefusion is sad...just sadxtremefusion is sad...just sad
What motor do you have? What turbo are you going to be using? What are you going to use for fuel management? You said you paid 700 for a turbo kit, please tell me you didn't get an SSautochrome kit...
xtremefusion is offline
Old 07-24-2005, 11:06 PM   #5 (permalink)
Car: 89 SI
b17a1
t3/t4 turbo
drag manifold
turbonetics wastegate
blitz blow off valve with all the oil lines, piping etc
my buddy put it on his type r and it was hella fast, he had to sell because of his new baby and needs the money
and my main question is i want to get a headgasket just to be safe, what type of head gasket do i get and can i get it from honda or acura. Also with the injectors too?
Old 07-24-2005, 11:07 PM   #6 (permalink)
IISaiNtII's Avatar
as long as you're running low boost pressures with a decent setup and tune, you'll be fine for
oem honda gasket will be fine as well
-Proverbs 16:31
- Martina Navratilova
IISaiNtII is offline
Old 07-24-2005, 11:11 PM   #7 (permalink)
Car: 89 SI
-fuel pump
-b16 (lsd tranny)
-flywheel
-clutch
-fuel rail
-fuel regulator
-water pump
-new timing belt
-itr valvetrain
is my setup pretty decent you think? so just get one for my b17a1? what kind of injectors?
Old 07-26-2005, 01:17 PM   #8 (permalink)
slowgoin is an unknown quantity at this point
go with 450's
go to homemadeturbo.com
wealth of friggin knowledge on turbo's there.you can also easily find the injectors over there for cheap.
slowgoin is offline
Old 07-26-2005, 02:19 PM   #9 (permalink)
Car: 1992 Honda prelude
Mods: stock
flip1199 is an unknown quantity at this point
Originally Posted by 89CivicHatch
-fuel pump
-b16 (lsd tranny)
-flywheel
-clutch
-fuel rail
-fuel regulator
-water pump
-new timing belt
-itr valvetrain
most of this stuf isnt' needed. only things i see that are needed are clutch, injectors and fuel pump. do u know what your gonna use for fuel management?
The Dark Side calls to you!!!
R.I.P.
360.4 whp and 409.9 ft-lbs of torque
turbo h23...
flip1199 is offline
Old 07-26-2005, 04:20 PM   #10 (permalink)
IISaiNtII's Avatar
none of that stuff is "needed" on a 5-8 psi setup on a motor that is still good for boost.
-Proverbs 16:31
Old 07-26-2005, 04:59 PM   #11 (permalink)
NegroDamus's Avatar
NegroDamus you're still here?NegroDamus you're still here?NegroDamus you're still here?NegroDamus you're still here?NegroDamus you're still here?NegroDamus you're still here?NegroDamus you're still here?NegroDamus you're still here?NegroDamus you're still here?NegroDamus you're still here?NegroDamus you're still here?
All you should get is.
Fuel management of some kind. (fmu at least)
Clutch.
New oem HG.
Timming belt.
The rest isnt required.
"One cannot truly see the light until he has felt the embrace of the abyss."
"Every facet, every department of your mind is to be programmed by you and unless you assume your rightful responsibility and begin to program your own mind, the world will program it for you."
01001100011010010110001001100101011100100111010001 10000101110011001000000101011001100101011011000010 000001001101011011110111001001110011
Reality, the greatest single thing there's never been.
NegroDamus is offline
Old 07-26-2005, 05:40 PM   #12 (permalink)
Car: 89 SI
Clutch.
New oem HG.
Timming belt.
you can delete this two post down i repost it so close it i got what i was looking for in the other post
Search Engi
