Where r u located? Let me tell you sound like U need a lot more research. Its all been covered in here. I know man, I don't like to hear that, I didn't back in the day when I was new in here. But you know what, you have to do your homework or you will just hurt your car. READ READ READ.
But just to let you know. NO, you don't need a boost controller with hondata. Hondata will ONLY control fuel and timing and cple other little things.. The wastegate controls your boost. WG(wastegate) has a spring inside of it that will predict how much boost you will run all the time. Now, to this wg you can add a boost controller and run more boost then what the WG spring is set for, but never less. The HONDATA will ONLY control fuel and timing.
Now for the manifold... There is countless of manifolds out there for Bseries motors. Be sure to dump your money into manifold, turbo, WG and fuel management. Those are the most important parts in a kit.
You really need more research though, so you can decide how much boost you can run on your motor and be ok stock or after is built or for daily driving, etc etc. RESEARCH its all in here...
2JZ SuCkAs ! !
Bye Bye FWD, hello RWD... :clap
Life is all about smiles and cries...Its all you got.
You have to control your smiles and your cries..
I'm Rich Bitch
