boost options on h22 hatch
i had already posted on the hybrid section about a guy here in town that has an eg hatch with an h22 in it. he was deciding between boosting it or going all motor. seems like his decision is going more twoards boosting it. and hes also thinking of the possibility of adding a stroker kit because he wants to build up his engine first. needless to say hes going to do everything right. any stroker kits that you guys recommend for boost? what compression should he run? he was wanting to get cams too but i told him to just refreshen the head, i.e valve job seals all that good stuff but leave the cams alone and let the turbo do the job. what do you guys think about that? oh and also do you guys think an accord oil pan will fit on an h22 too? i have a vtec and non vtec f22 at the shop and supposedly his oil drain is cross threaded. any other suggestions you guys may have?
