Old 11-24-2005, 04:48 PM   #1 (permalink)
Car: 1997 Turbo Honda Prelude SH
Mods: Fully built block with turbonetics t3/t4 turbo kit.
prelude1911 Rep God/Goddess with nothing better to doprelude1911 Rep God/Goddess with nothing better to doprelude1911 Rep God/Goddess with nothing better to doprelude1911 Rep God/Goddess with nothing better to doprelude1911 Rep God/Goddess with nothing better to doprelude1911 Rep God/Goddess with nothing better to doprelude1911 Rep God/Goddess with nothing better to doprelude1911 Rep God/Goddess with nothing better to doprelude1911 Rep God/Goddess with nothing better to doprelude1911 Rep God/Goddess with nothing better to doprelude1911 Rep God/Goddess with nothing better to do
boost questions on h22a4??
I have a fully built H22A4 engine in my 1997 Honda Prelude. Here a list of some mods that I have done.
Resleeve the block with ductile iron sleevs
wiseco 8:5:1 aluminum pistons
eagles connecting rods
skunk 2 valves, springs, and retainers
using turbonetics t3/t4 turbo
etc....
what is the max boost i can run with this setup? how high of a psi have other build honda engine run? please list engine, psi, and how long you been running?
Right now I am running 13psi making 250whp. I have to get a 3 bar map sensor and will do a retune with 20 or more psi depending on what i find out.
prelude1911 is offline
Old 11-24-2005, 08:06 PM   #2 (permalink)
Lifeless Ninja
98civcEK's Avatar
Car: 98 Civic DX
the amount of boost depends on the size of the turbo. the smaller the turbo the more psi you can set it to. the larger the less boost.
98civcEK is offline
Old 11-24-2005, 08:07 PM   #3 (permalink)
Iron Monk
street_accord94's Avatar
Car: 1994 CD7, 2007 Z4 3.0si
Mods: one time i tried to list them and i ran out of room...if you really want to know ask me.
street_accord94 Um, 1 million? Damn!street_accord94 Um, 1 million? Damn!street_accord94 Um, 1 million? Damn!street_accord94 Um, 1 million? Damn!street_accord94 Um, 1 million? Damn!street_accord94 Um, 1 million? Damn!street_accord94 Um, 1 million? Damn!street_accord94 Um, 1 million? Damn!street_accord94 Um, 1 million? Damn!street_accord94 Um, 1 million? Damn!street_accord94 Um, 1 million? Damn!
he speaks the truth...you should measure by the horsepower goals
Kevin - 1994 CD7 - 2007 Z4 3.0si Sport
street_accord94 is offline
Old 11-24-2005, 09:56 PM   #4 (permalink)
b16ahybrid has a spectacular aura aboutb16ahybrid has a spectacular aura aboutb16ahybrid has a spectacular aura about
Assuming your tuning and fuel set-up is up to the task you should be good for about 500whp or the max of that turbo which depends on the a/r.
Like it was said prior, you don't measure the limits in terms of boost pressure but in terms of power being made and quality of the tuning.
94 civic coupe,b16a turbo.
12.42 @118mph...*sold*
b16ahybrid is offline
Old 11-24-2005, 10:42 PM   #5 (permalink)
Well my goal is 400 plus whp. this is my first build. the turbo i read is good for 250-550hp. i am currently using stock cams with no port work. i only put on new skunk valves, springs, and retainers. kind of ran out of time. but i think i got everything on the car to be able to produce that kind of power. just need someone really good to tune it.
Old 11-25-2005, 04:23 AM   #6 (permalink)
GunMetal Member
Car: `97 Prelude Moneypit
Mods: Sleeved, Built, with Hondata
miikail is an unknown quantity at this point
you'll be good for tons of boost if you tune it right. You should look into higher compression pistons for some better low end power when you come off the line. I've been running this setup for about 3 years now and haven't had any issues. I have an H22A4 GE sleeved at 9.2:1 CR. You're head will be fine. the bottom end is the most important part in this build. You should run around 720cc injectors and get a good ems like Hondata, AEM, MoTeC or Haltech.
Turbo Prelude
359WHP 292TQ
FS: GT35RLE Turbo, 550cc RC injectors, TiAL 35mm WG, .5 bar TiAL Spring, Stock 18in 350Z Wheels, SH Rims with tires
miikail is offline
Old 11-25-2005, 05:16 AM   #7 (permalink)
Iron Monk
Car: 2004 Rsx Type S,1998 Twin Turbo Supra,Fiances car 2003 Evo 8
Mods: Ask to many to bother listing....Plus theres not enough room
GotBoost98 In the stratusphereGotBoost98 In the stratusphereGotBoost98 In the stratusphereGotBoost98 In the stratusphereGotBoost98 In the stratusphereGotBoost98 In the stratusphereGotBoost98 In the stratusphereGotBoost98 In the stratusphereGotBoost98 In the stratusphereGotBoost98 In the stratusphereGotBoost98 In the stratusphere
etc....
Did you even prep the trans at all?
Also im not sure why you need a CR of 8 anything A 9:5:1 or a 9:8:1 should be just fine for a street car...................... you went a bit over kill there..........you can still also hit 450whp with out having to run over 18psi you set up the turbo an size of everything correctly
2004 Acura Rsx Type S
2003 Evo 8 Fiance's car
2000 Acura Integra Type R::Stolen::
Gotboost? Im getting obnoxious in my old age
These are a must see guys check them out!!!
The Truth About Dyno Testing 139 DIY tuning Tips Cryogenic Treatment
Turbo Troubleshooting 101 Turbocharging Vs Supercharging Octane Facts
Turbo Sizing Code Breakers Honda Trade Secrets Tire Size Vs Power Production
GotBoost98 is offline
Old 11-25-2005, 03:28 PM   #8 (permalink)
well i have 750cc rc fuel injectors feeding from a aem fuel rail and aem fuel pressure regulator. I also added a walbro 250lph in tank fuel pump and have the hondata s200 system installed. i got the wiseco 8:5:1 compression pistons because i plan on running high boost and the only available gas here in sothern california is 91 octane. didn't want any problems with detonation. the first guy i had tune the car was kind of a rookie. next time i will have the shop owner do the tunning. here there webpage
http://home.earthlink.net/~spchurch/...motivetesting/
Old 11-25-2005, 03:30 PM   #9 (permalink)
I have a fidanza 8lb. aluminum flywheel, a 6 puck clutch with a stock pressure plate.
Old 11-25-2005, 03:32 PM   #10 (permalink)
Iron Monk
upgrade that pressure plate.....an you should be okay......id personally get a lsd with a drag spool as well
Old 11-27-2005, 07:18 AM   #11 (permalink)
GunMetal Member
what clutch. i had a 6 puck and had issues with it holding up top beyond 3rd gear. look into RPS or Spec.
Turbo Prelude
359WHP 292TQ
miikail is offline
Old 11-27-2005, 11:10 AM   #12 (permalink)
You can only run one or the other. An lsd is a limited slip diff, and a drag spool is like a welded differential only lighter and more expensive (same function, locks both wheels).. thats like running a header and a turbo manifold.
Old 11-27-2005, 12:31 PM   #13 (permalink)
Cypher Wave
Mods: h23vtec
98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy98vtec needs rep therapy
13psi and only 250whp?
H23vtec - 215/178 (stock head)
Blakes Wiki
ECU Chipping and Engine Management Services
Specializing in H series Engine Management
- willing to travel at customer expense
98vtec is offline
Old 11-27-2005, 01:01 PM   #14 (permalink)
Iron Monk
I wouldn't know ive only used Lsd...An I know what Lsd stands for You think im stupid?....never had experience with drag spools.. so its not like I would know if you could run both.......Ive never even seen one honestly..I guess it looks the same as a Lsd..Didnt know that it couldnt be used........Thanks for info.........*~Edited~* Just looked at a drag spool looks very close to a Lsd.........
Old 11-27-2005, 01:04 PM   #15 (permalink)
I wouldn't know ive only used Lsd.......never had experience with drag spools..
NP, just letting you now. Also so this guy doesn't go looking for an lsd with a drag spool....
