Originally Posted by jdmboy16
i want to boost this b18a im putting together im going to use eagle rods and just buy 600cc. injectors and a 255lph fuel pump and i have the safc controller but i should be able to run the revs past 7 grand right with the rods i mean it would be a stock head for alittle while but if i hit the rev limiter it should be alright?
i wouldnt go with 600cc injectors you can pick up dsm 350 injectors for less money and they will do just fine ofr about 12-14psi. With stock cams and stock springs i wouldnt take it past 6500 with a cam i wouldnt take it past 7000 with cams,springs and titanium retainers i wouldnt push it past 8500 just to be safe.
It's not safe to rev high on a stock head because if you go to high you will get valve float which is not good at all
