Old 11-13-2006, 02:50 PM   #1 (permalink)
fomik's Avatar
fomik is an unknown quantity at this point
BOV noob question
Hy... I'm a noob at this so please don't flame me
I heart that if you have a turbo system installed on your car, then you need to have a BOV (blow off valve) installed also, that is similar to a wastegate... but how do I set it at the chosen PSI ?
For example I'm runing 8 PSI at max RPM (8000), at how much presure should I set my BOV ? And how do it do it ? Do it just change the spring(s) like a wastegate? I'm confused.
Feel free to correct me if I'm wrong, or just point me to a BOV guide or something...
Thanx !
fomik is offline
Old 11-13-2006, 02:53 PM   #2 (permalink)
dom yo's Avatar
Car: tEh PiMpIn SaTuRn
Mods: mez :ninja
dom yo you're still here?dom yo you're still here?dom yo you're still here?dom yo you're still here?dom yo you're still here?dom yo you're still here?dom yo you're still here?dom yo you're still here?dom yo you're still here?dom yo you're still here?dom yo you're still here?
ive just started reading up on this stuff myself.. from what i know.. you do not need to set the BOV.. kinda just like a plug and play type deal.. its so you dont have so much pressure build up in the lines and intake manifold..
Original Pencil Pusher Thread.. never forget
Reppin Richmond
dom yo is offline
Old 11-13-2006, 03:52 PM   #3 (permalink)
Dark Wind
Snoopy's Avatar
Car: something with wheels
Mods: whole lot of nothing
blow off valves and wastegates are two different things.
wastegates are either internally mounted in the turbo or externally on the turbo manifold. their job is to regulate boost by opening a valve at a preset psi (usually determined by the spring inside them) to bleed off exhaust thus limiting boost.
blow off valves are mounted on the intake charge piping, or in some cases on the hot side of an air to air intercooler. their purpose is to vent the intake charge in the piping when the throttle closes so that the pressurized air doesnt make it's way back to the turbo, possibly causing damage.
Snoopy is offline
Old 11-14-2006, 10:30 AM   #4 (permalink)
fomik's Avatar
thx
Ok. Thanx for the info guys.
fomik is offline
Old 11-14-2006, 09:29 PM   #5 (permalink)
Car: 95 'lude SE
Mods: some stuff
twokexlv6coupe Needs to go outside once in awhiletwokexlv6coupe Needs to go outside once in awhiletwokexlv6coupe Needs to go outside once in awhiletwokexlv6coupe Needs to go outside once in awhiletwokexlv6coupe Needs to go outside once in awhiletwokexlv6coupe Needs to go outside once in awhiletwokexlv6coupe Needs to go outside once in awhiletwokexlv6coupe Needs to go outside once in awhiletwokexlv6coupe Needs to go outside once in awhiletwokexlv6coupe Needs to go outside once in awhiletwokexlv6coupe Needs to go outside once in awhile
there's usually a nut on the top of the BOV, and by turning this, you change the sound that the BOV makes.
but like dom said, its basically "plug and play"
"Yeah.. we gon' send this one out...to e'rybody that put mo' into they cars than they do they relationships...
Let's ride!"
-Luda-
twokexlv6coupe is offline
Old 11-17-2006, 12:22 PM   #6 (permalink)
loopedR6's Avatar
loopedR6 Rep God/Goddess with nothing better to doloopedR6 Rep God/Goddess with nothing better to doloopedR6 Rep God/Goddess with nothing better to doloopedR6 Rep God/Goddess with nothing better to doloopedR6 Rep God/Goddess with nothing better to doloopedR6 Rep God/Goddess with nothing better to doloopedR6 Rep God/Goddess with nothing better to doloopedR6 Rep God/Goddess with nothing better to doloopedR6 Rep God/Goddess with nothing better to doloopedR6 Rep God/Goddess with nothing better to doloopedR6 Rep God/Goddess with nothing better to do
HKS has said that the worst thing that they ever did was to put that nut on the back of the BOV. if it works then dont touch it.
1992 Integra GS
Motor: B18B, AIResearch T3, Johnny Racecar FMIC, Turbonetics Evolution WG, HKS SSQ BOV, DSM 450s, inline high flow fuel pump, MSD Blaster 2 coil, cap and rotor, tuned with Crome
Tranny: Stock LS w/ 6 puck Clutch Specialties clutch, ES shifter linkage bushings
Suspension: Tenzo-R lowering springs, KYB AGX struts
Cosmetic: 15" polished blades w/ Falken Ziex tires, black housing 1 piece headlights, shaved rear badges.
Interior: Kenwood head unit, aftermarket steering wheel, short shifter, Greddy Turbo Timer, blitz boost gauge, NGK wideband O2 sensor
loopedR6 is offline
