Old 11-02-2002, 12:39 PM   #1 (permalink)
B16a2vtec95 is an unknown quantity at this point
car stalled due to running to rich.. help?
well i was driving down the road and my car just shut off my friend said it was due to to much fuel we had to push start it.. and well... it worked but i need to lower it more.. i have a vafc.. but i don't know what to put it at.. and i also have a fmu which is causing it to run like it is.. can someone please help?
p.s. its a greddy kit.. running stock boost and stock injectors
Sohc mini me turbo going for 10lbs..
B16a2vtec95 is offline
Old 11-03-2002, 12:26 AM   #2 (permalink)
kommon_sense's Avatar
Car: 98 Civic Ex Coupe
you need to get that afc tuned on a dyno.
kommon_sense is offline
Old 11-03-2002, 06:52 AM   #3 (permalink)
Car: 1999 Honda S2000
Mods: Straightened exhausts, larger air filter, fuel controller. Port and polish and possible turbo later
Sunder is an unknown quantity at this point
How about just running more boost to use up the fuel instead?
If you're absolutely certain that it is too rich, just lower the settings in the AFC until the engine seems to run smoother with less smoke. Then get it dynoed properly. If you're not certain, then leaning it out could destroy your engine. :eek: So be certain. Be very certain.
The VAFC should also be only working on high throttle and/or high RPM. At other settings, your stock computer should be on closed loop, effectively ignoring the VAFC settings.
If it's stalling in low throttle, then you need to turn the fuel pressure regulator down.
MY99 S2000
13.9 @ 99mph
When the clutch drops, the BS stops.
Sunder is offline
Old 11-04-2002, 10:20 PM   #4 (permalink)
Superorb You need a lifeSuperorb You need a lifeSuperorb You need a lifeSuperorb You need a lifeSuperorb You need a lifeSuperorb You need a lifeSuperorb You need a lifeSuperorb You need a lifeSuperorb You need a lifeSuperorb You need a lifeSuperorb You need a life
the afc does the same thing that the fmu does, so they are prolly conflicting. if u ran 450cc injectors from a dsm, u could use the stock fuel pump and use the afc to tune it all out.
ken
FS:
- f22 automatic starter
- Auto Tranny Computer 90-97 Accord
S-Type Tail Light Mod, Email me for details on kit
Superorb is offline
