If you can find a starion/conquest at the junkyard it will only cost you around $50, online its going to be more like $150...and you don't need to run much more than that unless you are planning on some crazy boost.
I found a site a while back testing the efficiency of OEM intercoolers and the Starion/Conquest made it to the top with very little pressure drop.
2000 Civic EX Coupe 5-speed
