I noticed the compression on all JDM engines is a tad higher then the USDM. Now since I'm looking to do a turbo build should i be getting a usdm engine? I'm planning on sleeving the block and having compression lowering pistons in there. So what I'm getting at is since I'm using the compression lowering pistons, does it matter if i get JDM or USDM. Thanks
I was told by the guy at honda(I don't believe him fully) that the jdm gsr transmissions have a shorter gear ratio which he told me makes a huge difference. Is this true or misinformation? I am getting tons of misinformation from people in real life, so i always come here to verify it or not. Thanks again.
usdm and jdm gsr gear ratio's are the same. although the jdm had lsd as an option.
LSD- Limited Slip Differential.
If you dont have LSD, have you noticed that in a burnout only 1 wheel will spin? This is because your tranny puts power to the wheel with the least amount of traction. If youre stuck in the snow with 1 wheel spinning, youre getting power to the wheel with no traction. LSD allows power to go to the wheel that has traction, to essentially create a 2 wheel burnout. I kind of compare it to "posi-rear" that has a live axle spinning both wheels. The difference is with posi rear that both wheels spin at the same speed. When cornering, the outside wheel is supposed to spin faster than the inner, and posi-rear doesnt allow for that (so its mainly just for drag). LSD still allows the inner and outer wheels to spin at different speeds, while putting power to both wheels, instead of "skipping" around a turn. As far as performance gains- it wont make you have more power, but it will make you faster.
Integra Arsenal:
1991 LS Special Ed- Sold.
1998 Nissan 240SX SE New!
And a 2000 Suzuki SV650
And per your first post- since youre ripping out the internals anyway, just get whichever motor is cheaper. It makes no difference, as the compression difference is due to the pistons- which you wont be using.
Integra Arsenal:
is there an echo in here?
Originally Posted by Snoopy
if you're going to rip the internals out anyway, save yourself a little $$ and go with the cheaper engine. which is usually the usdm.
Integra Arsenal:
