the waste gate releases your exhaust gases. the way it functions is .
if your boosting 8 psi it takes 8lbs of pressure per square inch to force the gate open and give you your boost.
thats why the more you boost the longer it takes to spool because it takes more pressure to open the wastegate.
i hope this helps you to understand what the wastegate does
