Originally posted by YayAreaBoy
yea you can lower your compression ratio by gettin a thicker head gasket (cheaper)...also with the fmu setup i think the max you should boost is 6-7
true, however a thicker headgaket will throw his timing off.
I suggest building the engine (pistons at least) and tuning with an EMS. however, if you can't afford a standalone, then boost low/don't push it too hard/make sure you're running RICH.
