i had this turbo kit for like a month. the first 2 weeks i ran the external wastegate without a valve seat boosted to 5psi at 7000rpm what i wanted but it had an exhaust leak. so i put the valve seat on the wastegate and it worked great but know the car in second gear at 5500 rpm acts like it needs gas or if wants to stop moving can this be affected by the gas urun in ur car or is this a bigger problem
What type of tuning do you have? you can't just run boost on the stock map sensor/injectors without tuning. anything above 5 psi the map sensor freaks out and the car spits and pops.
Mods: CAI/H/E d16z6 swap soon to get a b16 or boost.
Agree with Burnt rubber you need to supply more background info like if you are stock and / or what injectors, plugs, system (chrome ecutune, hondata, piggyback types...) or the shitty FMU. please explain your set up more.
