Old 11-10-2002, 06:14 PM   #1 (permalink)
ExViTermini's Avatar
Car: 96 Honda Civic
Mods: H22, soon to be boosted.
ExViTermini is a jewel in the roughExViTermini is a jewel in the roughExViTermini is a jewel in the rough
Question Deltagate Wastegate vaccuum/boost lines....
ok, I'm gettin ready to install my turbo and there are two places on the wastegate to connect a hose, One is the vaccuum one on top next to the adjustments screw, and one is a boost hole on the bottom outer lip. Which one should I connect the hose to? I'm not using a boost controller of any sort yet..
ExViTermini is offline
Old 11-10-2002, 06:47 PM   #2 (permalink)
Lifeless Ninja
civperc's Avatar
a little OT, but why did you go with Deltagate over Tial? boost creep and spikes = bad.
Advertise on Superhonda
civperc is offline
Old 11-10-2002, 09:18 PM   #3 (permalink)
Car: 96 Honda Civic
Umm, yeah, it deals with turbocharging, and its under the turbocharger section, gee, how is this off topic?
Neway, its what came with my "kit".
Old 11-11-2002, 03:44 AM   #4 (permalink)
Defi4nce has a little shameless behaviour in the past
another question to add. If your not using a boost controller do you need to put vacum to the top of the wastegate?
93' Blk Civ Coupe
2.0 LS/VTEC Fully Built
Home____________Kaneohe
"The wicked rule, and the fools follow"
Defi4nce is offline
Old 11-11-2002, 02:51 PM   #5 (permalink)
Car: 94 lx accord turbo
Mods: turbo baby
rrei is on a distinguished road
u connect vaccum to the side port and leave the top open
rrei is offline
Old 11-11-2002, 02:54 PM   #6 (permalink)
Car: 96 Accord LX
x3mhonda will become famous soon enough
umm dude, i think wat he meant by o/t is the question that he asked about the tial vs deltagate. i think he would know what o/t means, he's a mod for a reason.
x3mhonda is offline
Old 11-11-2002, 11:37 PM   #7 (permalink)
Car: 98Honda prelude,97 Honda Civic
Mods: I/H/E 50 Nx kit prelude , Rev hard turbo 6th gen Civic
malakas07 is an unknown quantity at this point
ok I just installed a rev hard stage II kit with the same deltagate. Now my question is My car is only seeing 4# and the deltagate is set for 7. Any Ideas?
malakas07 is offline
Old 11-11-2002, 11:47 PM   #8 (permalink)
Mods: turbo baby
u mean 4psi if so do u have the side port to the turbo or the intake manifold,,, if the turbo the this is y u only see about 4 psi and the sping for the wastegate will never let u see 7 it s really a 6.5 spring and the most i ever see is 6
rrei is offline
Old 11-12-2002, 12:55 AM   #9 (permalink)
OK my wastegate has a line coming from the side Tee'd from the fuel pressure vacuum. There is a port on the side of the compressor housing, that I first used for a day untill somebody told me not to. Are you saying not to put a line from the compressor housing?
Old 11-12-2002, 07:35 AM   #10 (permalink)
Mods: turbo baby
yes that is what i was saying
rrei is offline
Old 11-12-2002, 07:37 AM   #11 (permalink)
Mods: turbo baby
u did adjust the nut on the top to get ur desired boost setting right
rrei is offline
Old 11-12-2002, 09:05 AM   #12 (permalink)
No I did not. I automatically assumed that it was set at 7psi straight from the factory. So did you have to adjust your's when you first got it? or was it set at 7psi already? I also thought it could be that the blow off valve was to loose as well.
Old 11-12-2002, 03:32 PM   #13 (permalink)
Mods: turbo baby
i had to adjust it from factory its at 4psi and u basically turbn the screw in the center inward for more boost
rrei is offline
Old 11-12-2002, 04:36 PM   #14 (permalink)
ok thanx man great help. I thought I probally had a leak or something
Old 11-13-2002, 05:10 PM   #15 (permalink)
ok checked all Vacuum lines and all clamps turned the wastegate down all the way and still seeing 4psi. Don't know now. maybe just a faulty wastegate
