normally u have to dremel out the o rings and they fit
so if i dremel out the o rings, i will need to buy new ones for the stock injectors too correct? can i pull out the o rings then dremel it, or do i have to do it on the intake manifold (i would hate to pull off the intake manifold)?
Lastly, which o ring set should i use the H22A1 or DSM?
