Wanted some info on EGT readings. I have a 92 civic si hb with the apexi turbo kit, @ 6psi what is a safe temp. (not too rich or not too lean) should I be seeing? I have my sensor mouted in the exhaust manifold and my EGT currently hits 760 Degrees Celsius. Is that too cold or too hot?
i think on most aluminum engines, 850 c. and up is not good, things start to melt! If you get that high, back off the throttle and wait for egt's to drop
02 Midnight Black Pearl WRX
Lots of Mod's
damn i probably melted a whole bunch of sh*t already..check this out...normal driving..my readings are 800-1100...i remember flooring it and the needle going all the way up to 1600 !!! i was like ohhhh damn..i backed off...my sensor is mounted on the manifold in between number 3&4.
