Old 02-26-2002, 04:46 AM   #1 (permalink)
motegi is an unknown quantity at this point
tech wrench f max turbo manual
hi guys,
can someone post or email me the manual for the f max turbo kit. cos i wanna know in detail about the install and all the parts that come with kit. down to how many checks valaves, fittings .etc etc..
thanks guys..
vtecmotegi@yahoo.com
motegi is offline
Old 02-26-2002, 04:46 PM   #2 (permalink)
turbo-kits is an unknown quantity at this point
There is a step by step install instruction on their site...
http://www.f-max.com/installpage.htm
www.TurboKits.com - Boosted!
Acura, BMW, Ford, Honda, Mazda, Mitsubishi, Nissan, Subaru, Toyota, Lexus & VW
turbo-kits is offline
Old 02-26-2002, 05:55 PM   #3 (permalink)
h23zero is an unknown quantity at this point
their site gives you a general how to install their kit. Check out their web site. They list what your going to get and options for your kit.
h23zero is offline
Old 02-26-2002, 06:12 PM   #4 (permalink)
thanks for the reply guys,
i have searched through the site and have not found what i really need.
th is the deal,
i am about to put together a turbo kit by myself that is why i'll need to know every single part that came with the kit, down to every single bolts and screws. i wanna do the install by myself and do not wanna have to run to the auto shops to get more parts if you know what i mean.
motegi is offline
Old 02-26-2002, 06:26 PM   #5 (permalink)
are you getting this kit or making a kit? If your getting this kit you really don't need much.
You get these in the FMAX kit;
t3/t4 turbo
manifold
Tial wastegate (.65)
IC piping
two lucas injectors
addtional fuel controller
front mount intercooler
HKS BOV
oil lines
vaccum line and 5 way tee
air filter and hose
BTM or HEAD GASKET
bolts for turbo down pipe and BOV
coupling for IC
taps for the oil pan
1 check valve with bracket
30psi map sensor
Thing you gotta get;
power steering fuild
zip ties
extra wires
copper gasket maker
9/16 drill bit
This is for the preludes. I don't know if the all their kits are the same. hope this helps.
h23zero is offline
Old 02-26-2002, 10:07 PM   #6 (permalink)
Car: 2000 Civic EX-T
redfox is infamous around these partsredfox is infamous around these partsredfox is infamous around these partsredfox is infamous around these partsredfox is infamous around these partsredfox is infamous around these partsredfox is infamous around these partsredfox is infamous around these partsredfox is infamous around these partsredfox is infamous around these partsredfox is infamous around these parts
zip ties
extra wires
copper gasket maker
9/16 drill bit
Pardon my ignorance, but what is the copper gasket maker?
http://www.londonautoclub.org
Image:
17x7.5 Konig Impact J-Spec;
Performance:
redfox is offline
Old 02-27-2002, 07:42 AM   #7 (permalink)
a liquid gasket maker.
h23zero is offline
Old 02-27-2002, 08:05 AM   #8 (permalink)
What exactly does it do? Could you describe it better? Do you need that to install a F-MAX kit on a Civic?
Image:
Performance:
redfox is offline
Old 02-27-2002, 03:01 PM   #9 (permalink)
All it is used for is make a thin silcone film gasket between two parts. Most of the parts are machine true (as flat and smooth as can be), But exhaust gases can still find the little leaks. By using the copper or grey gasket maker you fill in the imperfections. no leaks. hope this helps.
h23zero is offline
Old 02-27-2002, 07:57 PM   #10 (permalink)
Thanx, I'll get myself some of that.
Image:
Performance:
redfox is offline
