So, I know I need to change the fuel set-up for this. Question is, can I get buy on just a FMU? I plan on running about 7-8 psi. If not just an FMU, then what size/brand pump should I get? Would injectors the be necessary too - size/brand?
I'm on a limited budget, but I need reliability so I'll just have to dig up money. Thanks in advance for tips/comments.
well your also gonna need a manifold to mount that turbo on there. your deffinatly gonna need a fmu and fuel pump, try a vortech fmu and msd pump. and thats pretty much the basic things. also get a boost gauge for sure.
7-8 psi is shit on the 14b... many people here base psi on the turbos from bolt on kits... you can bolt up the 14b and be able to run about 15 psi.... you just need to lower the compression a little bit... the 14b isnt that big of a turbo... dont be afraid to turn up the boost... trust me, you wont be satisfied with 7-8 psi on that turbo
I know I need a manifold. I think I'm going to get a cast-iron manifold for a GSR, because I think those fit the B20. If not, I'll have a custom one fabricated.
So, a Vortech FMU, a pump, and a boost gauge. You think 15 psi is safe for the engine? Thanks again.
Originally posted by Mr. CR-V I know I need a manifold. I think I'm going to get a cast-iron manifold for a GSR, because I think those fit the B20. If not, I'll have a custom one fabricated.
Jason
NO......soflags-t don't mis-inform.
Don't run 15 psi on that or any stock honda engine.
You will run into several problems
1)15psi on any turbo is to much for a stock honda.
2)since this is a low budget build up you will be using the bare minimum like a fmu and larger fuel pump rite.
well here's a quick fmu lesson.
the fmu adds more fuel by raising the fuel pressure (blocking the fuel returning to the fuel tank).So when the injector opens more fuel is squirted into th cylinder each time it opens.So say you go with a 10:1 fmu (10:1 means that the fmu will raise the fuel pressure 10psi for every pound of boost the turbo makes) and 15psi of boost. here's a little math.
say 40psi is your idle fuel pressure so take
40+(10x15)= 190psi of fuel pressure.:eek:
So now you have 190psi of fuel going through fuel lines and connections designed for 60-65psi.
Then you have the problem of the fuel injector spray pattern (or lack there of).
Injectors should only run at about 75% duty cycle.Above that the life drops greatly along with power production.
It all realy comes down to the fact that the stock fuel system can not supply enough fuel for 15psi of boost.
Since your just getting started i would recomend about 5-7psi until you learn more and have more money to upgrade your fuel/ignition system to support more boost.Good luck
94 civic coupe,b16a turbo.
12.42 @118mph...*sold*
Sorry if i was kinda wondering around with the last post but i was trying to watch my daughter and type at the same time so i kept forgeting what i was going to type.Let me know if you have any questions.
Originally posted by Mr. CR-V What brand/size pump and brand/rating FMU do you recommend for my application then?
Also, can anyone confirm that a GSR turbo manifold will fit my B20 block? Thanks.
Jason
Most people go with a 255lph (liter per hour) fuel pump.Several companies make them like holly (walbro),msd,bosch,vorec,etc.When you order one make sure you specify that it 's for a forced induction engine.I know summit racing sells one made by holly that is designed for turbo/supercharged applications.
Most people just use a vortec or cartec fmu.With the vortec you will want to start with a 12:1 diaphram.
A manifold for gs-r will bolt up to any other b-series (except the older prelude) the only problem that you may fun into would be the turbo clearing your radiator or ac.I have a b-series drag manifold on my car and it angles forward a little.You can also contact south florida performance for a manifold they specialize in custom turbo manifolds for any car.I don't have a number handy because i'm on vacation but they advertise in ss,and import tuner.
first off, 15psi wont last long on that engine of yours, just because the turbo is ready for that, doesnt mean your engine is. as for FMU, its only a temporary fix to the problem at hand (getting proper fuel to engine) the vortech is a nice unit. if you are running stock injectors id stay with the 12:1 disc. add the fuel pump and boost around 6psi. you'll love it. if you decide to upgrade your injectors to say 310s your gonna wanna bring that FMU down to around 8 or even 6:1.
2000 Civic Si
DRAG turbo........faster then it looks
Isn't a TDO5-14B comparable with a medium to big size Garrett T3 turbo? A TDO5-14B at 7-8psi might not be that bad on a motor that has a cr of 8.8:1 or 9.6:1(don't know what year CRV MR. CR-V has), especially with the fuel setup everyone is telling Mr. CR-V to get. 15psi is a good number on a motor that has a cr of 7.8:1 like 1st gen DSM's. This is going on a B20 CRV motor right? If so then yes a GSR manifold will fit. My neighbor has a Greddy GSR cast turbo manifold on her setup. For fuel I would go with a good inline(Aeromotive, MSD, Airtex) or intank(Holly, Walbro) fuel pump, 310 cc injectors, 8:1 FMU, Apexi S-AFC, and adjustable FPR. When you save up some cash I would dump that setup and switch to Hondata or some other type of affordable standalone and up the boost since you have a low cr motor.
Originally posted by SoFlaGS-T 15 psi on the 14b will not give major cfm's like other turbos would... like the t3/t4, or the 18g... the 14b is a small turbo... i dont see why not
i had a friend who turbocharged his gsr. he was running 9psi and it only lasted a month before one of the cylinders went kabooom. you cant run 15psi on a high compression engine, so there is no way this guy can use 15psi on stock internals. on the other had ive been running 7psi on my civic for nearly a year without any problems on stock internals.
That turbo is about the same size as th one that comes in th greddy kit rite,well would you crank th boost up to 15psi on a stock civic with a greddy kit? no.
Like i explained before,there is no way in hell the fmu will work for 15 psi worth of boost.At 8psi and stock injectors your pushing it.Now if he had the funds available he could either
a) ditch the fmu route and go with hondata or accel dfi or
b) get a 4:1 fmu,fuel pump,500cc injectors and an apex afc.
but even then your still looking at 100psi of fuel.
Any way you look at it a stock engine will not hold 15psi of boost.Sure it's not flowing as much cfm's but the boost is going to be a lot hotter then it would be if it was say a t3t4.
small turbo + high boost = lots of heat
big turbo same high boost = less heat thus better quality boost.
I'm going to assume that from your sig that you own a gs-t so in that case 15psi is perfectly fine for your engine (i believe 12psi is stock) but on a n/a honda engine it is a whole different ball game.
The highest boost that i've heard of on a stock engine (daily driven) was 13psi and that was on an ls integra that has really good tuning,the type of tuning a fmu can't supply.and that was also a t3t4 turbo.
