Stock Honda gaskets are not metalic, that's why they tend to blow after awhile of running hot. Aftermarket metalic gaskets are less prone to blowing, but only the metalic ones.
http://www.londonautoclub.org
Image:
17x7.5 Konig Impact J-Spec;
Performance:
