Old 04-05-2006, 04:10 PM   #1 (permalink)
Brad98_teg's Avatar
Car: 1998 Integra LS
Mods: BoOsT
Brad98_teg has a Rep problemBrad98_teg has a Rep problemBrad98_teg has a Rep problemBrad98_teg has a Rep problemBrad98_teg has a Rep problemBrad98_teg has a Rep problemBrad98_teg has a Rep problemBrad98_teg has a Rep problemBrad98_teg has a Rep problemBrad98_teg has a Rep problemBrad98_teg has a Rep problem
Getting out of Limp mode
ok, I just got my wideband in and wanted to go ahead and start doing a little tuning.Im running just a down pipe right now and only have 1 O2 sensor bung on it. I switched to OBD1 so i just needed that one sensor. I took it out for a while and replaced it with my wideband. After about 10 minutes it went into limp mode and is running rich as hell. So obviously I took it out and replaced it with my O2 sensor. We attempted to reset the ECU by diconnecting the battery and turning on my lights and other things, but it still will not get out of limp mode. Any magical way that I can get out of it?
thanks
1998 Integra LS
13.9 @103 on street tires
Brad98_teg is offline
Old 04-05-2006, 04:14 PM   #2 (permalink)
Car: 93 prelude si vtec
Mods: jdm h22, header, high flow cat, cat back exhaust, cai, stage 1 exceddy clutch with 8 pound flywheel, gauges in a pod, system...much more to come
johnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhile
you are not im limp mode. if you were youd barely be able to drive the car. youre probably in open loop mode where the ecu reads stored information and doesent advanve the timing, dumps a shit ton of fuel in blah, blah, blah. to fix it...get a new ecu. when my lude was running like shit, i couldnt possibly believe that all these things could be wrong, and it not be the ecu so i ordered one from phearable.net and it fixed everything.
93 prelude, jdm h22a, lots of mods great car---FOR SALE
http://www.superhonda.com/forum/showthread.php?t=317981
2005 subaru sti---the beast
johnlude85 is offline
Old 04-05-2006, 04:20 PM   #3 (permalink)
Brad98_teg's Avatar
Mods: BoOsT
the thing is that my car is barly running. it wont go past 2k and im trowing a code
1998 Integra LS
Old 04-05-2006, 04:28 PM   #4 (permalink)
wel if thats the case...youre probably throwing more then one code. usually...if a car does in fact go into limp mode, ther is a huge problem with your ecu. replace it. but before buying anything expensive, just pull the codes and let us know what they are. i can help you out with getting information to diagnose the problems if i know what the codes are.
for my cel codes, i got to the last step on every flow chart i had which said "substitute a known good ecm". well it turned out that my problem was actually the ecu.
Old 04-05-2006, 06:19 PM   #5 (permalink)
Brad98_teg's Avatar
Mods: BoOsT
well, i found out what the problem was. Something was wrong with my map so I stuck in a basemap and its running fine.
thanks for the help.
1998 Integra LS
Old 04-05-2006, 06:38 PM   #6 (permalink)
good deal man, glad to hear ya fixed it.
Old 04-05-2006, 07:01 PM   #7 (permalink)
Dark Wind
iLLeFFeKt CiViC's Avatar
Car: 93 civic dx
drill another hole in your downpipe and weld an o2 bung and instal the wideband o2 in there.
1991 Galant VR-4
1989 Camry -daily beater
1993 Civic dx-sold
1991 Eclipse gsx-sold
iLLeFFeKt CiViC is offline
Old 04-05-2006, 09:05 PM   #8 (permalink)
Brad98_teg's Avatar
Mods: BoOsT
yeah plan to do that tomorrow
1998 Integra LS
