Make sure the block is sleeved, because as good as that sounds, it will be all a complete waste if the motor is not sleeved. Also, who are you getting it from? Make sure it is someone you trust!!!
Originally posted by dug why is he raising the compression? he needs to stick with stock or lower compression...especially since there is no real engine management listed...
dude, I have been noticing you keep suggesting people must lower their compression when turboing. It's not the case.
Originally posted by civperc dude, I have been noticing you keep suggesting people must lower their compression when turboing. It's not the case.
this is the first time i've actually suggested it, the other times were just showing why you would want lower compression.
i still don't under stand reasoning for raising compression, considering he's depending on a chipped ecu to handle his business.
EDIT: heres a quote from SAAB about compression:
The intercooler effectively cools the intake air, which reduces the risk of dangerous knocking. So the engine can be designed for a high compression ratio, and this automatically leads to low fuel consumption. The compression ratio of our new engine is 9 . 0 : 1 - which is among the highest on present-day standard turbocharged engines.
here's an engine designed to be forced inducted, still has lower compression than what that guy is shooting for in an engine that was never designed to be FI, most places would recommend to keep compression ratios at 8:1 or below...
but oh well, you don't have to have lower compression of course
yea true...the highest compression i've seen a factory turbo car have is 9.4:1....oh yea that was a porsche 911 turbo.
that engine is $38,000 by itself....its ecu is hard as shit to crack....i dont think a little honda with some aftermarket ecu and stronger sleeves is going to beat the work done by porsche and saab
Car: School, Grocery store cashier, auto detailer, DJ, and land scaper/farmer
Mods: PM me.. Too long to list (god it feels good to say that)
What about tuning/engine manegment??
..Your gonna need to get something a little better than a piggy-back if you want the power for the $$ you put into this setup. Your not gonna see real HP till you do. Remember tuning is the most important part on ANY setup if you want power.
i would say go with 9 or 9.5:1 cr and say dont waste your money on the zex camshaft, as a cam is not needed for a turbo setup (the gains will be veeery minimal)
good luck
Ben
also, golden eaghle sleeves are tops
99 Honda Civic Si
JDM Civic Type R rods
.20 JDM Civic Type R Pistons
Portflow port & polished cylinder head
Skunk2 stage 2 cams
AEM cam gears
Skunk2 intake manifold
RC Engineering 66mm throttle body
AEM short-ram intake
JDM ITR header
custom made testpipe
(JDM collector, USDM out)
Thermal R&D exhaust
Tanabe Sustec Pro coilovers
Energy suspension bushings
Comptech front and rear Strutbars
16" Rota Circit 8's
Nitto NT450's
