Old 05-09-2002, 09:45 AM   #1 (permalink)
Car: 1999 Civic VP
Mods: 17" Konig Tantrums, 205/40/17 Yokohama Paradas, Front Rear Strut Bars, AEM CAI, A'pexi Dunk cat-back, Hyperwhite hedalights/turnsignals, Clear/red tailights, Mirror tint faded to black (35% front windows, 20% back), Interior Blacklights, many mo
shypinoy99 is an unknown quantity at this point
GReddy BlueBox
I just got my turbo kit (it's used, but in great condition) the only problem is that I didn't get the bluebox (yet, i hope) but worst case scenario, if I don't get the bluebox, can I still run my turbo? I've heard that the bluebox only fools the ecu into thinking there's no boost running through the car, if that's the case, can I just use check valves in place of the bluebox? Also, do I need an FMU if i'm just running the GReddy stock 5.5psi on stock internals and stock fuel system? Thanks guys!
AEM CAI
Clear/red tailights
shypinoy99 is offline
Old 05-09-2002, 10:46 AM   #2 (permalink)
Car: 2002 civic si hatchback
themi6group is an unknown quantity at this point
the bluebox supposedly controls your fuel curve underload and it may also fool your map sensor. you need sometype of fuel management system for dependability. you definetly need a fmu. the fmu raises your fuel pressure and it helps deliver the fuel you need at any boost level. a check valve or missing link is needed to fool your map sensor into thinking it's only getting vacuum when you boost.
timing is everything
themi6group is offline
Old 05-09-2002, 09:20 PM   #3 (permalink)
b18c5turbo is an unknown quantity at this point
get an fmu ,fuel management or whatever that will give you more fuel or youl blow you engine for sure get an egt and a/f meter a must for tuning
b18c5turbo is offline
Old 05-10-2002, 12:05 AM   #4 (permalink)
Car: 1999 Civic VP
hmmm...interesting. Does anyone know what the "blackbox" (i guess this came out before the bluebox) does? Thanks!
AEM CAI
Clear/red tailights
Old 05-10-2002, 02:36 AM   #5 (permalink)
Car: Student
FBP Si 2000 is an unknown quantity at this point
I know the blackbox disables VTEC...I dont' hear people using it much now.
'00 FBP Si
FBP Si 2000 is offline
Old 05-10-2002, 06:19 AM   #6 (permalink)
that's true si but the black box definetly doesn't disable vtec because i just had a dyno with it, and a vafc, and vtec clearly kicked in at 5,500 rpm. it supposed to control the fuel curve but it doesn't seem to work for the 96-98 civics. i was running way too lean with it. don't even worry about it unless your ride is 92-95. if you need mine you can have it.
by the way anyone know how to post pics so i can show my dyno?
Old 05-10-2002, 08:38 AM   #7 (permalink)
Car: 1999 Civic VP
Well...good news and bad news guys. I got the blackbox today (as opposed to the Bluebox) but I own a 99 civic. So is this basically useless to me?? What should I do now to complete my turbo set up? I don't own a VAFC or anything of the like (my engine is the D16y7 non-vtec) Any suggestions??
AEM CAI
Clear/red tailights
Old 05-10-2002, 11:19 AM   #8 (permalink)
the black box wasn't designed for obd II cars. it only works for the 92-95 civic. i definetly wouldn't use it. it doesn't allow our cars to dump enough fuel. make sure you have a fmu. you should be able to run modestly at stock boost, no more until you address your fuel management. do your homework. good luck
Old 05-10-2002, 02:18 PM   #9 (permalink)
Car: 1999 Civic VP
ok..so could i buy the blue box instead?? (sorry if these sound like dumb questions, but I havn't been able to find much about it in my quest for boost) Or will I still run into the problem of being OBD II instead of like the older 92-95 OBD I civics? Thanks again guys!
AEM CAI
Clear/red tailights
Old 05-10-2002, 07:00 PM   #10 (permalink)
Car: 99 Civic Si
JPowers is an unknown quantity at this point
How much money do you want to spend?
I just bought a Greddy turbo kit w/blue box for my 99si, although it's not installed yet. Eventually when I have the money I plan on going with Hondata. From what I've read the blue box will give you problems (ie. blown engine) if you run too much boost. Some people are using a Vortech FMU instead of the blue box with the Greddy kit, but it's still a piggyback like the bluebox and they're spending money on things like Apexi VAFC in addition to other little half-assed bandaids. All this will add up. Decide now if you plan to run higher boost. If this is the case, just go with Hondata. You will have to pay for dyno tuning, but your car will have a perfect fuel curve and much more power. If not, then find someone who has the Greddy kit and has updated to Hondata or even $AEM. I'm sure they'd sell you the bluebox for cheap since it's just sitting there collecting dust. At stock boost levels the blue box should be fine.
JPowers is offline
Old 05-11-2002, 12:27 AM   #11 (permalink)
Car: 1999 Civic VP
Ok, i'm getting a little lost...so the vortech fmu can be used in place of the blue box??? I thought all the FMU did was raise hte fuel pressure in order to attain more fuel in the air/fuel mix? How can that be a piggy back? Also, from what I've been looking at the hondata website, they don't have anything for OBDII cars yet...or am I wrong? I want to run stock boost for now, but do plan on building up my engine to handle more, in which case i'd like to have a nice fuel management system (ie hondata, aem, greddy e-management, etc.)
AEM CAI
Clear/red tailights
Old 05-11-2002, 08:41 PM   #12 (permalink)
Car: 99 Civic Si
Yes, the Vortech FMU can be used in place of the bluebox. I was under the impression that the term 'piggyback' is used to describe something that tricks the ecu and doesn't directly control it. Go here for more info (you might need to cut and paste):
http://forums.clubsi.com/showflat.ph...ts&Main=525307
For the Hondata you need to buy an OBD1 ecu which is compatible with your engine then have it modified by a Hondata dealer. Here is a link to the ecu swap guide at Hondata:
http://www.hondata.com/ecuswapguide.html
You will also need to buy an OBD2 to OBD1 adapter harness. For some good information go here:
http://www.c-speedracing.com/onlinestore/hondata.html
I'm still learning this stuff myself, but I hope you find the information you need in these links. If not, then do some searches on clubsi.com. Some of those guys really know their shit. There is a Hondata groupbuy going on in the got boost forum of that site, check it out. ********** is also good, but their search feature doesn't work well.
JPowers is offline
Old 05-11-2002, 10:39 PM   #13 (permalink)
Car: Student
I don't recommend turning up the boost with the blue box...It's fine for the stock boost level..but I don't think it compensates for upping the boost.
'00 FBP Si
Old 05-12-2002, 02:26 AM   #14 (permalink)
Car: Good question
IdLeSnAkE is an unknown quantity at this point
I have the blue box for sale, but it is from a 96 gsr greddy turbo. I have no need for the blue box so if you are interested and if it fits on your car PM me or email me.
Loan Officer.
IdLeSnAkE is offline
