Originally Posted by searcychris
i was going to get a kit but it only gives you 43hp why is it so small compared to other kits and if there are thing to get more hp out of the kit it will be on a stock b16a it does not have to be carb leagel
thanks
chris
its a small turbo on there, however, you can up the power output...heres how:
I know the prelude greddy kits dont come with the E-Manage, but all the other ones do
get that retuned...its setup way too rich from Greddy
use the highest octane gas you can get....then refer to above
add a 2.5" or 3" downpipe and 3" piping
if you want to keep your A/C, a 3" dp might be a problem, however you can have a 2.5" flare out to a 3" dp as soon as clearance permits
then run either a 3" high flow cat or test pipe and 3" piping all the way back
greddy kits dont come with intercoolers...buy one!!!!
boost controller
and once you have all these things, tune the e-manage or hondata or whatever
youll see some nice gains
