Mods: i/h/e msd ext.coil,wires,ignition sys,front&rear sway bars front upper rea lower tie bars.soon to drop in gsr motor and auto to manual swap $5,000
-1 degree per psi
i think that is the general safe way to do.so if you are running 18btdc stock with 9lb of boost you would run 9btdc.that is the safest setting, but then you can adjust according to your style of driving .peace
